- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Unknown type error
- Date: Mon, 29 Jun 2015 17:04:46 +0200
That would be great.
P.
2015-06-29 17:02 GMT+02:00 Jonathan Leivent <jonikelee AT gmail.com>:
On 06/29/2015 10:43 AM, Pierre Courtieu wrote:
Quick answer (very common question). Try replaying the error after setting
this: "Set Printing All."
This will disable the hiding of implicit arguments and notations that make
you believe these two types are the same.
Best regards,
Pierre
Is there also a very common corresponding enhancement request: why not have Coq determine whether the two types will be visibly different when printed under the current settings - and if not, temporarily Set Printing All (and say that it is doing so to avoid confusion) in order to display a more meaningful error message - perhaps after first printing the type under current settings so that the user would have an easier time following the correspondence?
-- Jonathan
2015-06-29 16:31 GMT+02:00 Marcus Ramos <marcus.ramos AT univasf.edu.br>:
Hi,
What should I do when I get the following error message?
"The term "H29" has type "In (inl n) (map inl r')"
while it is expected to have type "In (inl n) (map inl r')"."
I am using Coq 8.4 pl14 in CoqIDE for Windows 8.
Thanks in advance,
Marcus.
- [Coq-Club] Unknown type error, Marcus Ramos, 06/29/2015
- Re: [Coq-Club] Unknown type error, Pierre Courtieu, 06/29/2015
- Re: [Coq-Club] Unknown type error, Jonathan Leivent, 06/29/2015
- Re: [Coq-Club] Unknown type error, Yann Régis-Gianas, 06/29/2015
- Re: [Coq-Club] Unknown type error, Marcus Ramos, 06/29/2015
