- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Dumb question about dep. pattern matching
- Date: Wed, 15 Jul 2015 11:56:47 -0700
Not sure about underlying causes, but I got the following to work.
James
Fixpoint nT n : Type :=
match n with
| 0 => unit
| S n' => match n' with
| 0 => Type -> Prop
| S n'' => ((Type -> Prop) * nT n')%type
end
end.
Fixpoint fT n : nT n :=
match n as n0 return nT n0 with
| 0 => tt
| S n' => match n' as n'0 return nT n'0 -> nT (S n'0) with
| 0 => fun _ => (fun T:Type=>True)
| S n'' => fun x => ((fun T:Type=>True), x)
end (fT n')
end.
On Wed, Jul 15, 2015 at 11:39 AM, Beta Ziliani <beta AT mpi-sws.org> wrote:
BetaThanks,which is horrible. Anyone knows of a better way to define this?I'm ashamed to ask this, I'm pretty sure this was answered somewhere.Even if I try to help Coq a bit with annotations, or even breaking the cases, it's the same: it is not considering n = S n'. The only way I found to deal with this is using Program (avoiding it to perform the substitutions!):
I'm trying to do a (what I thought was a) simple dependent function type nT and function of that type fT. More concretely, nT generates types [unit, Type->Prop, (Type->Prop)*(Type->Prop), ...]:
match n with
| 0 => unit
| 1 => Type -> Prop
| S n => ((Type -> Prop) * nT n)%type
end.
When I try to define the function fT, it fails:
Fail Fixpoint fT n : nT n :=
match n with
| 0 => tt
| 1 => (fun T:Type=>True)
| S n' => ((fun T:Type=>True), fT n')
end.
Failing with message:
Recursive call to fT has principal argument equal to
"S n0" instead of one of the following variables:
"n'" "n0".
Obligation Tactic := idtac.
Program Fixpoint fT n : nT n :=
match n as m return n = m -> nT m with
| 0 => fun _ => tt
| S n' => fun H1 =>
match n' return n = S n' -> nT (S n') with
| 0 => fun _ =>(fun P:Type => True)
| S n'' => fun H2 => ((fun P:Type => True), (_ (fT n') : nT (S n'')))
end eq_refl
end eq_refl.
Next Obligation.
intros; rewrite H1 in H2.
injection H2; intro H'.
rewrite H' in x.
exact x.
Defined.
Next Obligation.
auto.
Defined.P.S.: A simpler version fails in a weird way:
match n return nT n with
| 0 => tt
| S n' =>
match n' as m return n' = m -> nT (S m) with
| 0 => fun _ => ((fun T:Type=>True) : nT 1)
| S n'' => fun H2 => _ ((fun T:Type=>True), fT n')
end eq_refl
end.
Next Obligation.
intros.
rewrite <- H2.
simpl.
rewrite H2.
rewrite <- H2.
exact x.
Fail Defined.
Error: Error: Illegal application:
The term "@pair" of type
"forall (A : Type@{Coq.Init.Datatypes.23})
(B : Type@{Coq.Init.Datatypes.24}), A -> B -> A * B"
cannot be applied to the terms
"Type@{Top.1610} -> Prop" : "Type@{max(Set+1, Top.1610+1)}"
"nT n'" : "Type@{Top.1319}"
"fun _ : Type@{Top.1610} => True" : "Type@{Top.1610} -> Prop"
"fT n'" : "nT n'"
The 1st term has type "Type@{max(Set+1, Top.1610+1)}"
which should be coercible to "Type@{Coq.Init.Datatypes.23}".
- [Coq-Club] Dumb question about dep. pattern matching, Beta Ziliani, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, James Wilcox, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, Beta Ziliani, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, Frédéric Besson, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, Frédéric Besson, 07/16/2015
