- From: Frédéric Besson <frederic.besson AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Dumb question about dep. pattern matching
- Date: Thu, 16 Jul 2015 13:32:03 +0200
> On 15 Jul 2015, at 21:13, Beta Ziliani
> <bziliani AT famaf.unc.edu.ar>
> wrote:
> Hi Frédéric,
> On Wed, Jul 15, 2015 at 4:08 PM, Frédéric Besson
> wrote:
> Hi,
> Your code is working with 8.5beta2.
> Must be something new, I'm using 8.5 commit
> 851539eca5016da98253308749131abae3ec7b93 (June 5).
> Set Printing All shows the code provided by James.
> Uh? This is an answer to what?
Here is the script:
Fixpoint nT n : Type :=
match n with
| 0 => unit
| 1 => Type -> Prop
| S n => ((Type -> Prop) * nT n)%type
end.
Print nT.
Set Printing All.
Print nT.
and the output (coq8.5beta2):
nT =
fix nT (n : nat) : Type :=
match n with
| 0 => unit
| 1 => Type -> Prop
| S (S _ as n0) => ((Type -> Prop) * nT n0)%type
end
: nat -> Type
Argument scope is [nat_scope]
nT =
match n return Type with
| O => unit
| S n0 =>
match n0 return Type with
| O => forall _ : Type, Prop
| S _ => prod (forall _ : Type, Prop) (nT n0)
end
end
: forall _ : nat, Type
> Print produces:
> nT =
> match n with
> | 0 => unit
> | 1 => Type -> Prop
> end
> : nat -> Type
> Best,
> Frédéric
> > On 15 Jul 2015, at 20:39, Beta Ziliani
> > <beta AT mpi-sws.org>
> > wrote:
> > I'm ashamed to ask this, I'm pretty sure this was answered somewhere.
> > I'm trying to do a (what I thought was a) simple dependent function type
> > nT and function of that type fT. More concretely, nT generates types
> > [unit, Type->Prop, (Type->Prop)*(Type->Prop), ...]:
> > match n with
> > | 0 => unit
> > | 1 => Type -> Prop
> > end.
> > When I try to define the function fT, it fails:
> > Fail Fixpoint fT n : nT n :=
> > match n with
> > | 0 => tt
> > | 1 => (fun T:Type=>True)
> > | S n' => ((fun T:Type=>True), fT n')
> > end.
> > Failing with message:
> > Recursive call to fT has principal argument equal to
> > "S n0" instead of one of the following variables:
> > "n'" "n0".
> > Even if I try to help Coq a bit with annotations, or even breaking the
> > cases, it's the same: it is not considering n = S n'. The only way I
> > found to deal with this is using Program (avoiding it to perform the
> > substitutions!):
> > Obligation Tactic := idtac.
> > Program Fixpoint fT n : nT n :=
> > match n as m return n = m -> nT m with
> > | 0 => fun _ => tt
> > | S n' => fun H1 =>
> > match n' return n = S n' -> nT (S n') with
> > | 0 => fun _ =>(fun P:Type => True)
> > | S n'' => fun H2 => ((fun P:Type => True), (_ (fT n') : nT (S n'')))
> > end eq_refl
> > end eq_refl.
> > Next Obligation.
> > intros; rewrite H1 in H2.
> > injection H2; intro H'.
> > rewrite H' in x.
> > exact x.
> > Defined.
> > Next Obligation.
> > auto.
> > Defined.
> > which is horrible. Anyone knows of a better way to define this?
> > Thanks,
> > Beta
> > P.S.: A simpler version fails in a weird way:
> > match n return nT n with
> > | 0 => tt
> > | S n' =>
> > match n' as m return n' = m -> nT (S m) with
> > | 0 => fun _ => ((fun T:Type=>True) : nT 1)
> > | S n'' => fun H2 => _ ((fun T:Type=>True), fT n')
> > end eq_refl
> > end.
> > Next Obligation.
> > intros.
> > rewrite <- H2.
> > simpl.
> > rewrite H2.
> > rewrite <- H2.
> > exact x.
> > Fail Defined.
> > Error: Error: Illegal application:
> > The term "@pair" of type
> > "forall (A : Type@{Coq.Init.Datatypes.23})
> > (B : Type@{Coq.Init.Datatypes.24}), A -> B -> A * B"
> > cannot be applied to the terms
> > "Type@{Top.1610} -> Prop" : "Type@{max(Set+1, Top.1610+1)}"
> > "nT n'" : "Type@{Top.1319}"
> > "fun _ : Type@{Top.1610} => True" : "Type@{Top.1610} -> Prop"
> > "fT n'" : "nT n'"
> > The 1st term has type "Type@{max(Set+1, Top.1610+1)}"
> > which should be coercible to "Type@{Coq.Init.Datatypes.23}".
- [Coq-Club] Dumb question about dep. pattern matching, Beta Ziliani, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, James Wilcox, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, Beta Ziliani, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, Frédéric Besson, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, Frédéric Besson, 07/16/2015
