RE: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?
- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?
- Date: Tue, 4 Aug 2015 13:39:03 +0000
- Accept-language: de-DE, en-US
Dear Pierre, Cedric,
then I don’t understand what the problem with supporting nested lemmas is.
Best regards,
Michael
From: coq-club-request AT inria.fr [mailto:coq-club-request AT inria.fr]
On Behalf Of Pierre Courtieu
Nested lemmas are started in a fresh environment. Context dependent nested lemmas are not possible afaik.
Lemma A: TA. Proof. <part 1> Lemma B: TB. Proof. <part 2> Qed. <part 3>. Qed.
There is no reference to the proof context of A in the statement and proof of B. Once proved B is added to the global environment just as if it was proved before A. The only difference is that the <part 1> Is evaluated before B exists (hence if B Is moved outside of A <part 1> may behave differently especially if B Is added to some hint db).
Pierre
Dear Cedric,
I checked some of the lemmas I created as nested lemmas. None of them depends on the proof context explicitly and none of them gets any implicit context dependency added by Coq. When I “Check” the lemmas, they look as expected: no dependency on hypothesis in the proof context of when the lemma was started.
So how about disallowing context dependent nested lemmas? Of cause I need dependency on section variables, but not on the current proof context. As far as I understood, the others, who expressed interest in this feature, use it in a similar way.
Best regards,
Michael
Intel Deutschland GmbH |
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, (continued)
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Cedric Auger, 08/03/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Adam Chlipala, 08/03/2015
- RE: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Nick Benton, 08/03/2015
- [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Pierre Courtieu, 08/03/2015
- RE: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Soegtrop, Michael, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Cedric Auger, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Per Lindgren, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Pierre Courtieu, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Adam Chlipala, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Carlos . SIMPSON, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Enrico Tassi, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Clément Pit--Claudel, 08/05/2015
