Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?
- Date: Tue, 4 Aug 2015 15:45:50 +0200
Hi
The issue here is not the nested proof by itself, but rather the lifting inner proofs to be available to <part 1>, and thus changing its behavior? Or am I missing something (being a newbie)…
Per
On 04 Aug 2015, at 15:39, Soegtrop, Michael <michael.soegtrop AT intel.com> wrote:
Dear Pierre, Cedric,then I don’t understand what the problem with supporting nested lemmas is.Best regards,MichaelFrom: coq-club-request AT inria.fr [mailto:coq-club-request AT inria.fr] On Behalf Of Pierre Courtieu
Sent: Tuesday, August 04, 2015 3:16 PM
Subject: Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?Nested lemmas are started in a fresh environment. Context dependent nested lemmas are not possible afaik.Lemma A: TA.Proof.<part 1>Lemma B: TB.Proof.<part 2>Qed.<part 3>.Qed.There is no reference to the proof context of A in the statement and proof of B. Once proved B is added to the global environment just as if it was proved before A. The only difference is that the <part 1> Is evaluated before B exists (hence if B Is moved outside of A <part 1> may behave differently especially if B Is added to some hint db).PierreDear Cedric,I checked some of the lemmas I created as nested lemmas. None of them depends on the proof context explicitly and none of them gets any implicit context dependency added by Coq. When I “Check” the lemmas, they look as expected: no dependency on hypothesis in the proof context of when the lemma was started.So how about disallowing context dependent nested lemmas? Of cause I need dependency on section variables, but not on the current proof context. As far as I understood, the others, who expressed interest in this feature, use it in a similar way.Best regards,MichaelIntel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Prof. Dr. Hermann Eul
Chairperson of the Supervisory Board: Tiffany Doon Silva
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, (continued)
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Adam Chlipala, 08/03/2015
- RE: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Nick Benton, 08/03/2015
- [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Pierre Courtieu, 08/03/2015
- RE: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Soegtrop, Michael, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Cedric Auger, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Per Lindgren, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Pierre Courtieu, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Adam Chlipala, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Carlos . SIMPSON, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Enrico Tassi, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Clément Pit--Claudel, 08/05/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Enrico Tassi, 08/05/2015
