Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?
- Date: Tue, 04 Aug 2015 17:03:38 +0200
Dear Adam, Dear All, This seems to be an interesting question. Perhaps it rather points to a need for a mechanism for recording a trace of Ltac calculations in an external file, which could be reloaded at subsequent passages of that point in the proof process. In that case, when you arrive at a point where a long Ltac calculation has been made, but realize you need a lemma, you could save the Ltac trace (which should be available during the current proof script); back up, put the lemma in before, and then recover up to the place where the lemma is to be used by having Ltac use its saved trace as a big "hint". This type of capability would certainly be useful elsewhere, not to speak of what happens the next day when you try to rerun the proof. All the best, ---Carlos Simpson Le 04/08/2015 16:36, Adam Chlipala a
écrit :
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, (continued)
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Cedric Auger, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Per Lindgren, 08/04/2015
- RE: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Soegtrop, Michael, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Pierre Courtieu, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Adam Chlipala, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Carlos . SIMPSON, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Enrico Tassi, 08/04/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Clément Pit--Claudel, 08/05/2015
- Re: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Enrico Tassi, 08/05/2015
- RE: [Coq-Club] "Nested proofs are deprecated and will stop working in the next Coq version" - Can we keep this?, Soegtrop, Michael, 08/05/2015
