- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] coq in ubuntu
- Date: Tue, 1 Sep 2015 09:32:50 +0000
- Accept-language: de-DE, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga02.intel.com
- Ironport-phdr: 9a23:7iXd1BFMgdLGZpUm841yiJ1GYnF86YWxBRYc798ds5kLTJ75oM2wAkXT6L1XgUPTWs2DsrQf27GQ7PurADdIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/njKbtoNaKOE1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvNa8/VPlTCCksG2Ez/szi8xfZB0Pb7XwFF24SjxBgAg7f7Ri8UI2n4QXgse8okhKdMMLqV7csHXyH7qxrQRLswm9TMj8y8Gjajopri69UvAimvzR+xZLZZMeeM/8oLfCVRs8TWWcUBpUZbCdGGI7pN4Y=
I guess you mean the key combinations with Alt-key. The problem is that Unity uses the Alt key for its own purposes. So you can either tell Unity or CoqIDE to use a different key.
In CoqIDE you can do this under Edit/Preferences/Shortcuts easily.
In Unity I think it is more complicated because afaik you need to disable/redefine each shortcut individually, e.g. using the unity tweak tool.
Best regards,
Michael
From: coq-club-request AT inria.fr [mailto:coq-club-request AT inria.fr]
On Behalf Of Patricia Peratto
I have installed coq in Ubuntu (versión 12.04) and the Navigation commands does not work.
How can I arrange this?
Regards, Patricia Intel Deutschland GmbH |
- [Coq-Club] coq in ubuntu, Patricia Peratto, 08/31/2015
- RE: [Coq-Club] coq in ubuntu, Soegtrop, Michael, 09/01/2015
- Re: [Coq-Club] coq in ubuntu, Patricia Peratto, 09/08/2015
- Re: [Coq-Club] coq in ubuntu, Ali Assaf, 09/09/2015
- Re: [Coq-Club] coq in ubuntu, Patricia Peratto, 09/18/2015
- Re: [Coq-Club] coq in ubuntu, Ali Assaf, 09/19/2015
