coq-club - Re: [Coq-Club] coq in ubuntu
  • To: coq-club AT inria.fr
  • Cc: ali.assaf AT inria.fr
  • Subject: Re: [Coq-Club] coq in ubuntu
  • Date: Fri, 18 Sep 2015 15:51:41 -0300 (UYT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=psperatto AT vera.com.uy; spf=Pass smtp.mailfrom=psperatto AT vera.com.uy; spf=None smtp.helo=postmaster AT mta02.vera.com.uy
  • Dkim-filter: OpenDKIM Filter v2.9.0 mta05.in.vera.com.uy 0F9D0221830
  • Ironport-phdr: 9a23:LRJHMRMin1zH5+nRcdgl6mtUPXoX/o7sNwtQ0KIMzox0KPvyrarrMEGX3/hxlliBBdydsKIYzbGK+Pm5EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35jxjLz5osSbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lor88dLUu33eq05SfRUCzEvMmZn+sDxvF/ISg7J+2pUEj5OylsbSzTCuRr9R9L6tjbwnut7wiiTe8PsHp4uXjH31653Uh7jiS5PDzMj+X3LjYQklLlDrQiouwB465DZeojTP/17OL7MK4BJDVFdV9pcAnUSSri3aJECWrFZZes=
I have tried modifying the shortcuts
from Preferences and it does not work.
I have modified the file coqide.keys.
When I try to execute it, the ; at the begining
of the file gives the syntactic error.
I guess the reason why this does not work
is because my version of coq is 8.3 pl 4
and I need a version greater or equal to
8.4.
I couldn't find a version of coq for
ubuntu- precise greater or equal than
8.4.
Regards,
Patricia
De: "Ali Assaf" <ali.assaf AT inria.fr>
Para: coq-club AT inria.fr
Enviados: Miércoles, 9 de Septiembre 2015 17:47:33
Asunto: Re: [Coq-Club] coq in ubuntu
Hi Patricia,
To correct Michael's answer, the default shortcuts for navigation are Ctrl + Alt + something (you can see them in the navigation menu), but Ctrl + Alt + arrow is used by Unity and Gnome to switch between workspaces. You can change the navigation shortcuts by going to Edit -> Preferences -> Shortcuts. For example, you can depress the Ctrl key next to "Modifiers for Navigation Menu" so that you can use Alt + arrow to navigate instead.
However, I remember that in some old versions of Coq, changing the shortcuts from the Preferences window simply did not work (the shortcuts would not change) and that I had to go edit some configuration file to replace Ctrl + Alt by just Alt. Unfortunately I don't remember exactly which file it is. I am guessing this is what you tried to do. Did you try the coqiderc file? I am not sure what you mean by "gives a syntactic error". What gives you this message?
Best,
Ali Assaf
From: "Patricia Peratto" <psperatto AT vera.com.uy>
Sent: Tuesday, September 8, 2015 2:42:33 PM
I couldn't configure the navigation commands.
(fwd, back, goto, etc) I have tried modifying the
coqide.keys file but the ; at the begining of the file
gives a syntactic error.
The coq version I have installed is 8.3 from
April 2012. The Ubuntu I have installed is
Precise.
I have tried modifying Edit/Preferences/Shortcuts
but it didn't work.
What can I do?
Regards,
Patricia
De: "Michael Soegtrop" <michael.soegtrop AT intel.com>
Enviados: Martes, 1 de Septiembre 2015 6:32:50
Asunto: RE: [Coq-Club] coq in ubuntu
Dear Patricia,
I guess you mean the key combinations with Alt-key. The problem is that Unity uses the Alt key for its own purposes. So you can either tell Unity or CoqIDE to use a different key.
In CoqIDE you can do this under Edit/Preferences/Shortcuts easily.
In Unity I think it is more complicated because afaik you need to disable/redefine each shortcut individually, e.g. using the unity tweak tool.
Best regards,
Michael
From: coq-club-request AT inria.fr [mailto:coq-club-request AT inria.fr] On Behalf Of Patricia Peratto
Sent: Monday, August 31, 2015 11:23 PM
To: coq-club
Subject: [Coq-Club] coq in ubuntu
I have installed coq in Ubuntu (versión 12.04) and the Navigation
commands does not work.
How can I arrange this?
Regards,
Patricia
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Prof. Dr. Hermann Eul
Chairperson of the Supervisory Board: Tiffany Doon Silva
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
