- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] coq in ubuntu
- Date: Tue, 8 Sep 2015 09:42:33 -0300 (UYT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=psperatto AT vera.com.uy; spf=Pass smtp.mailfrom=psperatto AT vera.com.uy; spf=None smtp.helo=postmaster AT mta04.in.vera.com.uy
- Dkim-filter: OpenDKIM Filter v2.9.0 mta05.in.vera.com.uy 673DB2209D4
- Ironport-phdr: 9a23:WSYg2xJwif0kaPVtmtmcpTZWNBhigK39O0sv0rFitYgULfXxwZ3uMQTl6Ol3ixeRBMOAu64C0rCd4vqocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC04LujavjodX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD8/gl/sVDGaj/dqU8BbBfCT0nNTIr6dfi8xLESE2S9zNcCT1O00kAPw+Q5xbjG5z1ryHSt+xn2SDcM9elY6ozXGGa5rtxSRTpgW8/OiQw7H3Qwphol7pWuhu9uxtX3YPOaceeM/84Y7KLLoBSfnZIQssEDn8JOYi7dYZaVLJZMA==
Para: coq-club AT inria.fr
Enviados: Martes, 1 de Septiembre 2015 6:32:50
Asunto: RE: [Coq-Club] coq in ubuntu
I guess you mean the key combinations with Alt-key. The problem is that Unity uses the Alt key for its own purposes. So you can either tell Unity or CoqIDE to use a different key.
In CoqIDE you can do this under Edit/Preferences/Shortcuts easily.
In Unity I think it is more complicated because afaik you need to disable/redefine each shortcut individually, e.g. using the unity tweak tool.
Best regards,
Michael
From: coq-club-request AT inria.fr [mailto:coq-club-request AT inria.fr] On Behalf Of Patricia Peratto
Sent: Monday, August 31, 2015 11:23 PM
To: coq-club
Subject: [Coq-Club] coq in ubuntu
I have installed coq in Ubuntu (versión 12.04) and the Navigation
commands does not work.
How can I arrange this?
Regards,
Patricia
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Prof. Dr. Hermann Eul
Chairperson of the Supervisory Board: Tiffany Doon Silva
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
- [Coq-Club] coq in ubuntu, Patricia Peratto, 08/31/2015
- RE: [Coq-Club] coq in ubuntu, Soegtrop, Michael, 09/01/2015
- Re: [Coq-Club] coq in ubuntu, Patricia Peratto, 09/08/2015
- Re: [Coq-Club] coq in ubuntu, Ali Assaf, 09/09/2015
- Re: [Coq-Club] coq in ubuntu, Patricia Peratto, 09/18/2015
- Re: [Coq-Club] coq in ubuntu, Ali Assaf, 09/19/2015
