- From: Washington Ribeiro <wtonribeiro AT gmail.com>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Mutually recursive functions with a decreasing measure
- Date: Sat, 19 Sep 2015 19:55:59 -0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=wtonribeiro AT gmail.com; spf=Pass smtp.mailfrom=wtonribeiro AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f178.google.com
- Ironport-phdr: 9a23:SxinKxNXyX2sb+VQMHwl6mtUPXoX/o7sNwtQ0KIMzox0KPj4rarrMEGX3/hxlliBBdydsKIYzbGI+PG5EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35jxjL75qsSbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5jfZSg7a2XIHUmQQnQZPBUD/7Rv3X432+n/lqu17wiiQMMzsSpg7XD2j6+FgTxq+23RPDCIw7GyC0p84t6lcuh/0/xE=
Here is an example of the problem with defining recursive functions. Is a recursive function that checks if two lists of naturals ar AC-equivalent.
Require Import List.
Require Import Recdef.
Require Import Omega.
Require Import Coq.Program.Wf Coq.Program.Program Coq.Program.Tactics.
(* A predicate for deciding if to naturals are equal *)
Definition eq_nat_dec_Prop (m n : nat) : Prop :=
if (eq_nat_dec m n) then True else False.
Notation "n == m" := (eq_nat_dec_Prop n m) (at level 67).
(* Removes the ith element of a list *)
Fixpoint rem_ith (i:nat) (l:list nat) : list nat :=
match i, l with
_ , nil => nil
| 0 , n::l0 => l0
| S i0, n::l0 => n::(rem_ith i0 l0)
end.
(* A inductive definition to represent an
Associative-Commutative equivalence between two lists of naturals*)
Inductive ac_ind : (list nat) -> (list nat) -> Prop :=
ac_ind_nil : ac_ind ([]) ([])
| ac_ind_1 : forall i n1 n2 l1 l2,
i < length l2 ->
(n1 == (nth i l2 0)) ->
(ac_ind l1 (rem_ith i l2)) ->
ac_ind (n1::l1) (n2::l2)
(* An auxiliar function for computing n-ary disjunctions *)
Fixpoint ac_aux (R : nat -> Prop) (n : nat) : Prop :=
match n with
0 => R 0
| S n0 => R (S n0) \/ ac_aux R n0
end .
(* With the Fixpoint nested recursion is ok, but it's impossible to define a
decreasing parameter *)
Fixpoint ac_rec1 (l l' : list nat) {struct l} : Prop :=
match l,l' with
| nil, nil => True
| n1::l1, l2 => let R0 (i:nat) := (n1 == (nth i l2 0)) /\
(ac_rec1 l1 (rem_ith i l2)) in
ac_aux R0 (length l2 - 1)
| _ , _ => False
end.
(* And there is no problem to simplify applying the function definition *)
Lemma ac_ind_eq_ac_req1 : forall l l', ac_ind l l' <-> ac_rec1 l l'.
Proof.
intros. split; intro. induction H.
simpl; trivial.
simpl. Admitted.
(* Here using Program Fixpoint one can defines a measure at the same time
that has nested recursion *)
Program Fixpoint ac_rec2 (l l' : list nat) {measure (length l)} : Prop :=
match l,l' with
| nil, nil => True
| _ , _ => False
end.
Solve All Obligations with
split; intros; intro Q; case Q; clear Q;
intros Q1 Q2; inversion Q1; inversion Q2.
(* Now isn't possible to simplify with non-ground terms *)
Lemma ac_ind_to_ac_rec2 : forall l l' , ac_ind l l' <-> ac_rec2 l l'.
Proof.
compute. trivial.
compute. Admitted.
(* Defining a measure for the pair L *)
Definition left_length (L : list nat * list nat) := length (fst L).
(* And with Function it is possible to have a recursive function with
a decreasing measure but nested recursion isn't allowed *)
(* Output:
Toplevel input, characters 0-340:
Error: the term fun i : nat => n1 == nth i l2 0 /\ ac_rec3 (l1, rem_ith i l2)
can not contain a recursive call to ac_rec3
Function ac_rec3 (L : list nat * list nat) {measure left_length} : Prop :=
match L with
| (nil, nil) => True
| (n1::l1, l2) => let R0 (i:nat) := (n1 == (nth i l2 0)) /\
(ac_rec3 (l1, (rem_ith i l2))) in
| (_ , _) => False
end.
Dear,
It's possible to define in Coq a mutually recursive function with a decreasing measure and with a automatically generated rewriting equation?
I've used three different kind of definitions as follow:
| Muttually recursive | Decreasing measure | Rewriting equation |
Fixpoint | Yes | No | Yes |
Function | No | Yes | Yes |
Program Fixpoint | Yes | Yes | No |
So my problem is that I never have a definition with a automatically generated rewriting equation that allows to explicit a decreasing parameter and that is muttually recursive.
Best,
Washington
- [Coq-Club] Mutually recursive functions with a decreasing measure, Washington Ribeiro, 09/17/2015
- <Possible follow-up(s)>
- [Coq-Club] Mutually recursive functions with a decreasing measure, Washington Ribeiro, 09/20/2015
- Re: [Coq-Club] Mutually recursive functions with a decreasing measure, Pierre Courtieu, 09/22/2015
- Re: [Coq-Club] Mutually recursive functions with a decreasing measure, Washington Ribeiro, 09/22/2015
- Re: [Coq-Club] Mutually recursive functions with a decreasing measure, Pierre Courtieu, 09/23/2015
- Re: [Coq-Club] Mutually recursive functions with a decreasing measure, Washington Ribeiro, 09/23/2015
