coq-club - Re: [Coq-Club] Mutually recursive functions with a decreasing measure
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Washington Ribeiro <wtonribeiro AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Mutually recursive functions with a decreasing measure
  • Date: Wed, 23 Sep 2015 01:00:12 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-wi0-f170.google.com
  • Ironport-phdr: 9a23:u8CHsRWKfyAi/PNMZzEdp+Ioa9zV8LGtZVwlr6E/grcLSJyIuqrYZh2Gt8tkgFKBZ4jH8fUM07OQ6PC8HzBZqs/e+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8GVP1wD3WX1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu3SNp41Rr1ADTkgL3t9pIiy7UGCHkOz4S4jW34WkxxHHw/DpCv7VJrwqCyy4vVh3y+APMf7TKozcTun5qZvDhTvjXFUGSQ+9TTvi8Fqlq8TixW8vQB+zpOcNJmUOeBkc+XWes4AWWtMQ+5eUiVABsW3aI5ZXLlJBvpRs4So/whGlhC5HwT5Qbq3kjI=
I think you should be able to prove things, but first prove the fixpoint equality (by hand) and then rewrite with it instead of using simpl/cbn. the proof of the equality should use simpl/cbn.
P.
2015-09-22 21:53 GMT+02:00 Washington Ribeiro <wtonribeiro AT gmail.com>:
Sorry Pierre,
I didn't understand but my problem is that in my proofs I am using another structure (a term signature) to compare modulo AC. So the simplest way I see to do this is with nested recursion. There is no way to do proofs with simplification and Program Fixpoint definitions?
Best,
Washington
2015-09-22 10:31 GMT-03:00 Pierre Courtieu <pierre.courtieu AT gmail.com>:
Hi Washington,
2015-09-20 0:55 GMT+02:00 Washington Ribeiro <wtonribeiro AT gmail.com>:
Here is an example of the problem with defining recursive functions.  Is a recursive function that checks if two lists of naturals ar AC-equivalent.
Require Import List.
(* Here using Program Fixpoint one can defines a measure at the same time
 that has nested recursion *)
Program Fixpoint ac_rec2 (l l' : list nat) {measure (length l)} : Prop :=
match l,l' with
 | nil, nil => True
 | n1::l1, l2  => let R0 (i:nat) := (n1 == (nth i l2 0)) /\
                                    (ac_rec1 l1 (rem_ith i l2)) in
                                     ac_aux R0 (length l2 - 1)
 | _ , _ => False
end.
There is a typo here, you should use ac_rec2. But it works anyway.
Why do you call this nested recursion?
Solve All Obligations with
split; intros; intro Q; case Q; clear Q;
intros Q1 Q2; inversion Q1; inversion Q2.
(* Now isn't possible to simplify with non-ground terms *)
Lemma ac_ind_to_ac_rec2 : forall l l' , ac_ind l l' <-> ac_rec2 l l'.
Proof.
 intros. split; intro. induction H.
 compute. trivial.
 compute. Admitted.
(* Defining a measure for the pair L *)
Definition left_length (L : list nat * list nat) := length (fst L).
(* And with Function it is possible to have a recursive function with
 a decreasing measure but nested recursion isn't allowed *)
(* Output:
Toplevel input, characters 0-340:
Error: the term fun i : nat => n1 == nth i l2 0 /\ ac_rec3 (l1, rem_ith i l2)
can not contain a recursive call to ac_rec3
Function ac_rec3 (L : list nat * list nat) {measure left_length} : Prop :=
match L with
 | (nil, nil) => True
 | (n1::l1, l2)  => let R0 (i:nat) := (n1 == (nth i l2 0)) /\
                                      (ac_rec3 (l1, (rem_ith i l2))) in
 | (_ , _) => False
end.
Indeed Function does not support nested recursion. Actually here recursive calls are nested but not the decreasing argument so this is "gentle" nested recursion.
A remark here, Function supports multiple arguments, use the syntax (slightly different syntax in the curly brackets):
Program Fixpoint ac_rec3 (l l' : list nat) {measure length l} : Prop :=
From: Washington Ribeiro <wtonribeiro AT gmail.com>
To: coq-club AT inria.fr
Subject: [Coq-Club] Mutually recursive functions with a decreasing measure
Date: Thu, 17 Sep 2015 09:47:36 -0300
Dear,
It's possible to define in Coq a mutually recursive function with a decreasing measure and with a automatically generated rewriting equation?
I've used three different kind of definitions as follow:
Muttually recursive
Decreasing measure
Rewriting equation
Fixpoint
Yes
No
Yes
Function
No
Yes
Yes
Program Fixpoint
Yes
Yes
No
So my problem is that I never have a definition with a automatically generated rewriting equation that allows to explicit a decreasing parameter and that is muttually recursive.
Best,
Washington
