- From: Washington Ribeiro <wtonribeiro AT gmail.com>
- To: coq-club AT inria.fr
- Cc: Pierre Courtieu <pierre.courtieu AT gmail.com>
- Subject: Re: [Coq-Club] Mutually recursive functions with a decreasing measure
- Date: Tue, 22 Sep 2015 16:53:53 -0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=wtonribeiro AT gmail.com; spf=Pass smtp.mailfrom=wtonribeiro AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f179.google.com
- Ironport-phdr: 9a23:jWjnBxCjkP9WZhUe94W4UyQJP3N1i/DPJgcQr6AfoPdwSP79oMbcNUDSrc9gkEXOFd2CrakU16yK6+u5BTdIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/ni6buo9aKP14ArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIZoGJ/3dKUgTLFeEC9ucyVsvJWq5lH/Sl6E4WJZWWELmDJJBRLE5Vf0RMTfqCz/49V0wymbO8LqSrZ8YzWo4qZxT1e8lzsAMSQ4+mzWkMtYg6dSoRbnrBt6ld2HKLqJPeZzK/uONegRQnBMC4MID3RM
Sorry Pierre,
I didn't understand but my problem is that in my proofs I am using another structure (a term signature) to compare modulo AC. So the simplest way I see to do this is with nested recursion. There is no way to do proofs with simplification and Program Fixpoint definitions?
Best,
Washington
2015-09-22 10:31 GMT-03:00 Pierre Courtieu <pierre.courtieu AT gmail.com>:
Hi Washington,2015-09-20 0:55 GMT+02:00 Washington Ribeiro <wtonribeiro AT gmail.com>:Here is an example of the problem with defining recursive functions. Is a recursive function that checks if two lists of naturals ar AC-equivalent.Require Import List.[...](* Here using Program Fixpoint one can defines a measure at the same timethat has nested recursion *)Program Fixpoint ac_rec2 (l l' : list nat) {measure (length l)} : Prop :=match l,l' with| nil, nil => True| n1::l1, l2 => let R0 (i:nat) := (n1 == (nth i l2 0)) /\(ac_rec1 l1 (rem_ith i l2)) inac_aux R0 (length l2 - 1)| _ , _ => Falseend.There is a typo here, you should use ac_rec2. But it works anyway.Why do you call this nested recursion?Solve All Obligations withsplit; intros; intro Q; case Q; clear Q;intros Q1 Q2; inversion Q1; inversion Q2.(* Now isn't possible to simplify with non-ground terms *)Lemma ac_ind_to_ac_rec2 : forall l l' , ac_ind l l' <-> ac_rec2 l l'.Proof.intros. split; intro. induction H.compute. trivial.compute. Admitted.(* Defining a measure for the pair L *)Definition left_length (L : list nat * list nat) := length (fst L).(* And with Function it is possible to have a recursive function witha decreasing measure but nested recursion isn't allowed *)(* Output:Toplevel input, characters 0-340:Error: the term fun i : nat => n1 == nth i l2 0 /\ ac_rec3 (l1, rem_ith i l2)can not contain a recursive call to ac_rec3*)Function ac_rec3 (L : list nat * list nat) {measure left_length} : Prop :=match L with| (nil, nil) => True| (n1::l1, l2) => let R0 (i:nat) := (n1 == (nth i l2 0)) /\(ac_rec3 (l1, (rem_ith i l2))) inac_aux R0 (length l2 - 1)| (_ , _) => Falseend.Indeed Function does not support nested recursion. Actually here recursive calls are nested but not the decreasing argument so this is "gentle" nested recursion.A remark here, Function supports multiple arguments, use the syntax (slightly different syntax in the curly brackets):Program Fixpoint ac_rec3 (l l' : list nat) {measure length l} : Prop :=...Dear,It's possible to define in Coq a mutually recursive function with a decreasing measure and with a automatically generated rewriting equation?I've used three different kind of definitions as follow:
Muttually recursive
Decreasing measure
Rewriting equation
Fixpoint
Yes
No
Yes
Function
No
Yes
Yes
Program Fixpoint
Yes
Yes
No
So my problem is that I never have a definition with a automatically generated rewriting equation that allows to explicit a decreasing parameter and that is muttually recursive.Best,Washington
- [Coq-Club] Mutually recursive functions with a decreasing measure, Washington Ribeiro, 09/17/2015
- <Possible follow-up(s)>
- [Coq-Club] Mutually recursive functions with a decreasing measure, Washington Ribeiro, 09/20/2015
- Re: [Coq-Club] Mutually recursive functions with a decreasing measure, Pierre Courtieu, 09/22/2015
- Re: [Coq-Club] Mutually recursive functions with a decreasing measure, Washington Ribeiro, 09/22/2015
- Re: [Coq-Club] Mutually recursive functions with a decreasing measure, Pierre Courtieu, 09/23/2015
- Re: [Coq-Club] Mutually recursive functions with a decreasing measure, Washington Ribeiro, 09/23/2015
