- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Dependent Type Problem
- Date: Thu, 17 Dec 2015 19:10:39 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=smolka AT ps.uni-saarland.de; spf=None smtp.mailfrom=smolka AT ps.uni-saarland.de; spf=None smtp.helo=postmaster AT theia.rz.uni-saarland.de
- Ironport-phdr: 9a23:qyVElhTOdmcP33B3ewzNfZ2WKtpsv+yvbD5Q0YIujvd0So/mwa64YxGN2/xhgRfzUJnB7Loc0qyN4/6mAjVLuM7f+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8OVOFwD3WLjKZpJbzyI7izp/vEMhoVjLqtjgjDomVBvP9ps+GVzOFiIlAz97MrjtLRq8iBXpu5zv5UYCfayV+0CQLdZFDUrNXwurI2u7EGbDFjH2nxJeWIP2jFMHgKNuBr9R9L6tjbwnut7wiiTe8PsG+MaQzOnuohmUgOgsyIAMz0wuDXMj8t0j6tzuAnnuhp+hpXdaZuRPfxyOK/QK4BJDVFdV9pcAnQSSri3aJECWq9YZb5V
Suppose we have an isomorphism between nat and a type N with O' and S'. I
would expect that the recursor for nat can be pulled over to N. In fact, it
is not difficult to define a function
R : forall f : N -> Type, f O' -> (forall x, f x -> f (S' x)) -> forall x, f
x.
However, I cannot show the equation
R f A F O' = A
because a rewrite violates dependent type constraints.
I would much appreciate help from a dependent type expert. Do you think it
is possible to define R in such a way that the equation can be shown? Or is
it known that the equations of dependent recursors cannot be pulled over?
Coq code is below.
Gert
PS. It is not difficult to pull over a simply typed recursor (primitive
recursion) including the equations.
Section N.
Variables (N : Type) (O' : N) (S' : N -> N).
Fixpoint E (n : nat) : N :=
match n with
| O => O'
| S n' => S' (E n')
end.
Variables (P : N -> nat).
Variable EP : forall x, E (P x) = x.
Variable PE : forall n, P (E n) = n.
Lemma PO' :
P O' = 0.
Proof.
now rewrite <- (PE 0).
Qed.
Lemma fEP (f : N -> Type) x :
f (E (P x)) -> f x.
Proof.
intros A. now rewrite <- EP.
Defined.
Definition R (f : N -> Type) (A : f O') (F: forall x, f x -> f (S' x)) x :
f x
:= fEP f x (nat_rect (fun n => f (E n)) A (fun n B => F (E n) B) (P x)).
Lemma R0 f A F :
R f A F O' = A.
Proof.
unfold R. pattern (P O’). FAILS
End N.
- [Coq-Club] Dependent Type Problem, Gert Smolka, 12/17/2015
- Re: [Coq-Club] Dependent Type Problem, Abhishek Anand, 12/17/2015
- Re: [Coq-Club] Dependent Type Problem, Gert Smolka, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Abhishek Anand, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Thorsten Altenkirch, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Jason Gross, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Bruno Barras, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Nicola Gambino, 12/18/2015
