- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Dependent Type Problem
- Date: Fri, 18 Dec 2015 10:39:40 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f182.google.com
- Ironport-phdr: 9a23:Muy10hUG8Wf1ok+IXOfirmceVULV8LGtZVwlr6E/grcLSJyIuqrYZhGFt8tkgFKBZ4jH8fUM07OQ6PC+HzRYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh770o8WbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSRGAtNHlw78n2vzHCSxGO7z0SSDNFvABPBl3s5hH7RZf8sWPTsON71GHONMf2TKs0VDfk5qFiThOuiSYbOBY29WjWjop7i6cN80HpnAB234OBONLdD/F5ZK6IJd4=
Sorry for forgetting to add explanation. Here is some that may help in understanding the proof.
1) the lemma eq_rect2 is better known as "J rule" in intensional type theory. It is a fundamental induction principle for eliminating proofs of equality. Whenever rewrite fails, I try to manually invoke this J rule. It is particularly useful when a computation is stuck at a match on a proof of equality.
2) In the proof of R0, after the initial unfolding, one sees that the computation is stuck at something like:
`match p with ... eq_refl`.
This computation only proceeds when p is in normal form. Fortunately, this is exactly what the J rule provides. Informally, it says that to show a property about an arbitrary proof of equality, it suffices to show it for its normal form, which is eq_refl.
To apply the J rule (`eq_rect2`), often the most difficult task is to come up with its argument P. Generalizing over the equality proof `p` often results in an ill typed term. To make it we'll typed, I had to replace `A` with `A'`. The types of `A` and `A'` are not same. But I still have to remember that `A` and `A'` were the same. This is where the `eq_dep` relation comes handy. It can be used to assert equality on members of dependent types whose indices are not definitionally equal. So I add `eq_dep A A' ` as a hypothesis in my instantiation for P.
After invoking eq_rect2 as H and applying H, the proof p gets replaced by eq_refl, and the computation happily proceeds. Also, after applying H, the types of `A` and `A'` become definitionally equal. Because the equality in N is decidable, using a lemma in the library, one can show that `eq_dep A A'` implies `A=A'`.
--Abhishek
http://www.cs.cornell.edu/~aa755/
> On 17 Dec 2015, at 22:07, Abhishek Anand <abhishek.anand.iitg AT gmail.com> wrote:
> I have reduced your proof to showing that equality on N is decidable, which should be easy.
> Require Import Coq.Unicode.Utf8.
> Require Import Coq.Logic.EqdepFacts.
> Require Import Coq.Logic.Eqdep_dec.
> Lemma eq_rect2
> : forall (T : Type) (x : T) (P : ∀ t : T, eq x t → Type),
> P x (eq_refl x) → ∀ (y : T) (e : eq x y), P y e.
> Proof.
> intros.
> rewrite <-e. assumption.
> Qed.
> Lemma NDec: ∀ x y : N, {x = y} + {x ≠ y}.
> Admitted.
> Lemma R0 f A F :
> R f A F O' = A.
> Proof.
> unfold R, fEP, eq_rect.
> remember
> (fun (z:N) (p:(E (P O'))=z) => forall A',
> eq_dep _ _ _ A _ A' ->
> match p in (_ = y) return (f y) with
> | eq_refl =>
> nat_rect (fun n : nat => f (E n)) A
> (fun (n : nat) (B : f (E n)) => F (E n) B)
> (P O')
> end = A'
> ) as PP.
> pose proof (fun pp => @eq_rect2 N _ PP pp) as H.
> subst PP.
> apply H; auto.
> rewrite PO'. simpl.
> intro. apply eq_dep_eq_dec.
> exact NDec.
> Qed.
> Print Assumptions R0.
> Section Variables:
> Axioms:
> NDec : ∀ x y : N, {x = y} + {x ≠ y}
> -- Abhishek
> On Thu, Dec 17, 2015 at 1:10 PM, Gert Smolka <smolka AT ps.uni-saarland.de> wrote:
> Suppose we have an isomorphism between nat and a type N with O' and S'. I would expect that the recursor for nat can be pulled over to N. In fact, it is not difficult to define a function
> R : forall f : N -> Type, f O' -> (forall x, f x -> f (S' x)) -> forall x, f x.
> However, I cannot show the equation
> R f A F O' = A
> because a rewrite violates dependent type constraints.
> I would much appreciate help from a dependent type expert. Do you think it is possible to define R in such a way that the equation can be shown? Or is it known that the equations of dependent recursors cannot be pulled over? Coq code is below.
> Gert
> PS. It is not difficult to pull over a simply typed recursor (primitive recursion) including the equations.
> Section N.
> Variables (N : Type) (O' : N) (S' : N -> N).
> Fixpoint E (n : nat) : N :=
> match n with
> | O => O'
> | S n' => S' (E n')
> end.
> Variables (P : N -> nat).
> Variable EP : forall x, E (P x) = x.
> Variable PE : forall n, P (E n) = n.
> Lemma PO' :
> P O' = 0.
> Proof.
> now rewrite <- (PE 0).
> Qed.
> Lemma fEP (f : N -> Type) x :
> f (E (P x)) -> f x.
> Proof.
> intros A. now rewrite <- EP.
> Defined.
> Definition R (f : N -> Type) (A : f O') (F: forall x, f x -> f (S' x)) x : f x
> := fEP f x (nat_rect (fun n => f (E n)) A (fun n B => F (E n) B) (P x)).
> Lemma R0 f A F :
> R f A F O' = A.
> Proof.
> unfold R. pattern (P O’). FAILS
> End N.
- [Coq-Club] Dependent Type Problem, Gert Smolka, 12/17/2015
- Re: [Coq-Club] Dependent Type Problem, Abhishek Anand, 12/17/2015
- Re: [Coq-Club] Dependent Type Problem, Gert Smolka, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Abhishek Anand, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Thorsten Altenkirch, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Jason Gross, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Bruno Barras, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Nicola Gambino, 12/18/2015
