- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Dependent Type Problem
- Date: Fri, 18 Dec 2015 12:14:11 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=smolka AT ps.uni-saarland.de; spf=None smtp.mailfrom=smolka AT ps.uni-saarland.de; spf=None smtp.helo=postmaster AT triton.rz.uni-saarland.de
- Ironport-phdr: 9a23:KSPg/B+Ak6coqv9uRHKM819IXTAuvvDOBiVQ1KB90O4cTK2v8tzYMVDF4r011RmSDduds6oMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47AblHf6ke/8SQVUk2mc1EleKKtQsb7tIee6aObw9XreQJGhT6wM/tZDS6dikHvjPQQmpZoMa0ryxHE8TNicuVSwn50dxrIx06vrpT4wJk2+CNJ/vkl6sRoUKPgfq1+Q6YLIi4hNjUa6df3/SLGSg+M7zNISWARlhlBKxDeqgz8X9LquyLgsuN71G+WMJulHvgPRT2+4vIzG1fTgyAdOmth/Q==
Dear Abhishek, many thanks for your impressive proof. I’ll try to digest and
do the proof for S’. Gert
> On 17 Dec 2015, at 22:07, Abhishek Anand
> <abhishek.anand.iitg AT gmail.com>
> wrote:
> I have reduced your proof to showing that equality on N is decidable, which
> should be easy.
> Require Import Coq.Unicode.Utf8.
> Require Import Coq.Logic.EqdepFacts.
> Require Import Coq.Logic.Eqdep_dec.
> Lemma eq_rect2
> : forall (T : Type) (x : T) (P : ∀ t : T, eq x t → Type),
> P x (eq_refl x) → ∀ (y : T) (e : eq x y), P y e.
> Proof.
> intros.
> rewrite <-e. assumption.
> Qed.
> Lemma NDec: ∀ x y : N, {x = y} + {x ≠ y}.
> Admitted.
> Lemma R0 f A F :
> R f A F O' = A.
> Proof.
> unfold R, fEP, eq_rect.
> remember
> (fun (z:N) (p:(E (P O'))=z) => forall A',
> eq_dep _ _ _ A _ A' ->
> match p in (_ = y) return (f y) with
> | eq_refl =>
> nat_rect (fun n : nat => f (E n)) A
> (fun (n : nat) (B : f (E n)) => F (E n) B)
> (P O')
> end = A'
> ) as PP.
> pose proof (fun pp => @eq_rect2 N _ PP pp) as H.
> subst PP.
> apply H; auto.
> rewrite PO'. simpl.
> intro. apply eq_dep_eq_dec.
> exact NDec.
> Qed.
> Print Assumptions R0.
> Section Variables:
> Axioms:
> NDec : ∀ x y : N, {x = y} + {x ≠ y}
> -- Abhishek
> http://www.cs.cornell.edu/~aa755/
> On Thu, Dec 17, 2015 at 1:10 PM, Gert Smolka
> <smolka AT ps.uni-saarland.de>
> wrote:
> Suppose we have an isomorphism between nat and a type N with O' and S'. I
> would expect that the recursor for nat can be pulled over to N. In fact,
> it is not difficult to define a function
> R : forall f : N -> Type, f O' -> (forall x, f x -> f (S' x)) -> forall x,
> f x.
> However, I cannot show the equation
> R f A F O' = A
> because a rewrite violates dependent type constraints.
> I would much appreciate help from a dependent type expert. Do you think it
> is possible to define R in such a way that the equation can be shown? Or
> is it known that the equations of dependent recursors cannot be pulled
> over? Coq code is below.
> Gert
> PS. It is not difficult to pull over a simply typed recursor (primitive
> recursion) including the equations.
> Section N.
> Variables (N : Type) (O' : N) (S' : N -> N).
> Fixpoint E (n : nat) : N :=
> match n with
> | O => O'
> | S n' => S' (E n')
> end.
> Variables (P : N -> nat).
> Variable EP : forall x, E (P x) = x.
> Variable PE : forall n, P (E n) = n.
> Lemma PO' :
> P O' = 0.
> Proof.
> now rewrite <- (PE 0).
> Qed.
> Lemma fEP (f : N -> Type) x :
> f (E (P x)) -> f x.
> Proof.
> intros A. now rewrite <- EP.
> Defined.
> Definition R (f : N -> Type) (A : f O') (F: forall x, f x -> f (S' x)) x
> : f x
> := fEP f x (nat_rect (fun n => f (E n)) A (fun n B => F (E n) B) (P x)).
> Lemma R0 f A F :
> R f A F O' = A.
> Proof.
> unfold R. pattern (P O’). FAILS
> End N.
- [Coq-Club] Dependent Type Problem, Gert Smolka, 12/17/2015
- Re: [Coq-Club] Dependent Type Problem, Abhishek Anand, 12/17/2015
- Re: [Coq-Club] Dependent Type Problem, Gert Smolka, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Abhishek Anand, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Thorsten Altenkirch, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Jason Gross, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Bruno Barras, 12/18/2015
- Re: [Coq-Club] Dependent Type Problem, Nicola Gambino, 12/18/2015
