coq-club - Re: [Coq-Club] Proper morphisms for family of functions
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Proper morphisms for family of functions
  • Date: Wed, 6 Jan 2016 00:46:50 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f171.google.com
  • Ironport-phdr: 9a23:lCXVcxf4tl1gF3CmmYO4v7jClGMj4u6mDksu8pMizoh2WeGdxc6/Zh7h7PlgxGXEQZ/co6odzbGG7ea4ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTpkbjqs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR/QMBzM/dmsx+cfDtB/ZTALJ6GFKAUsMlR8dKgLF7Qr6U5S5my3zsOY1jCCQPcztTb03Hz2k5qFnDh7plCgvODsw8WWRgct12vEI6Cm9rgByltaHKLqeM+BzK/vQ
Sorry, I forgot that I had to make another fix to your code.
When declaring the `Equivalence` instance, you have to mention which relation is being declared as an equivalence.
Otherwise, Coq makes a wrong choice -- it introduces an arbitrary new relation.
That fix was as follows:
  Context `{Ae: Equiv A} `{Equivalence A Ae}.
To be safe, I have included the entire source, checked with 8.5 beta3 on Linux.
Require Import MathClasses.interfaces.canonical_names.
Require Import MathClasses.theory.setoids.
Require Import MathClasses.implementations.peano_naturals.
Section Operators.
  (* simple operators *)
  Class O (op: A -> A) :=
    op_proper :> Proper ((=) ==> (=)) (op).
  (* meta-operators *)
  Class MO2 (mop: (A->A) -> (A->A) -> A -> A) :=
    mop_proper :> Proper (((=) ==> (=)) ==> ((=) ==> (=)) ==> (=) ==> (=)) (mop).
  (* currued meta-operators are operators *)
  Instance MO_O `{Of: O f, Og: O g, MO2m: MO2 m}: O (m f g).
  Proof.
    apply MO2m; [apply Of | apply Og].
  Qed.
  (* TODO: Need this to use reflexivity on operators, but currently it is defined to widely, not just for operators but for any functions *)
  Instance Reflexive_ext_equiv_A: Reflexive (@ext_equiv A Ae A Ae).
  Proof.
    intros a x x' E.
    admit.
  Admitted.
  Section Test.
    (* sample operators *)
    Parameters o1 o2 o2': A->A.
    Instance O_o1: O o1. Proof. admit. Admitted.
    Instance O_o2: O o2. Proof. admit. Admitted.
    Instance O_o2': O o2'. Proof. admit. Admitted.
    (* Sample meta-operator *)
    Parameter X: (A->A) -> (A->A) -> A -> A.
    Instance X_MO2: MO2 X.  Proof.  admit. Admitted.
    (* two of operators are equal *)
    Axiom oo: o2 = o2'.
    (* this works *)
    Lemma foo:
      X o1 o2 = X o1 o2'.
    Proof.
      apply X_MO2; [reflexivity | apply oo].
    Qed.
    Lemma bar:
      X o1 o2 = X o1 o2'.
    Proof.
      rewrite oo. (* works *)
      reflexivity.
    Qed.
On Wed, Jan 6, 2016 at 12:28 AM, Vadim Zaliva <vzaliva AT cmu.edu> wrote:
On Jan 5, 2016, at 21:14 , Abhishek Anand <abhishek.anand.iitg AT gmail.com> wrote:
2) Fields of typeclasses are NOT automatically added to the database used for typeclass resolution. You need to mark that explicitly by replacing ":" with ":>".
For example, rewrite works in your `bar` after you change your `MO2` as follows:
Thanks! I just tried this and it did not work even though I can see mop_proper instance via 'Print Instances Proper’.
I am using Coq 8.4.
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Skype: vzaliva
