- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Proper morphisms for family of functions
- Date: Thu, 7 Jan 2016 20:04:05 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f181.google.com
- Ironport-phdr: 9a23:SPbkhhDtbCr3lv6OPuUAUyQJP3N1i/DPJgcQr6AfoPdwSP7+pcbcNUDSrc9gkEXOFd2CrakU1ayO6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6MyZzvn8mJuLTtICxwzAKnZr1zKBjk5S7wjeIxxbVYF6Aq1xHSqWFJcekFjUlhJFaUggqurpzopM0roGxsvKcq8NcFWqHndexsRrtBST8iLmod5cvxtBCFQxHZtVUGVWBDuxBIAhPF4RKyd5H4tCey4uN32CiBPcD1C7kyUDKuqaZqVBDAhyIONjp/+2bS3J8jxJlHqQ6s8kQsi7XfZ5uYYaJz
As you noted, extensional equality on function types is only a partial equivalence relation in cases where the domain type has a non-syntactic equality -- reflexivity only holds for functions that are setoid morphisms.
Perhaps the Reflexive class was not designed to cover such partiality.
You can make a set type of functions that are setoid morphisms, but additional work (eta expansion of dependent pairs) would be needed before invoking reflexivity.
Instead, you can redefine `reflexivity` using Ltac, as Jason showed in a coq-club post on 12/23/15.
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Wed, Jan 6, 2016 at 1:08 AM, Vadim Zaliva <vzaliva AT cmu.edu> wrote:
On Jan 5, 2016, at 21:46 , Abhishek Anand <abhishek.anand.iitg AT gmail.com> wrote:Sorry, I forgot that I had to make another fix to your code.Thanks! That was it. Now about your other suggestion:1) Take a look at MathClasses.theory.setoids.ext_equiv_reflMoreover, you might want to reuse MathClasses.interfaces.abstract_algebra.Setoid_Morphism instead of defining your own `O`.That was also super helpful! I still want to have my own class but I just defined it as:Class O (op: A -> A) :=o_setoidmor :> Setoid_Morphism op.and if I use `apply ext_equiv_refl` instead of `reflexivity` everything works just great. Here is full example: http://ideone.com/rbD6rv reworked per your suggestions.However I am still wondering if there is a way to declare such refined/specialized instance of ‘Reflexive’ for Setoid_Morphisms soreflexivity tactics would work as well?Sincerely,
Vadim Zaliva--CMU ECE PhD candidateMobile: +1(510)220-1060Skype: vzaliva
- Re: [Coq-Club] Proper morphisms for family of functions, Gregory Malecha, 01/01/2016
- Re: [Coq-Club] Proper morphisms for family of functions, Vadim Zaliva, 01/01/2016
- <Possible follow-up(s)>
- Re: [Coq-Club] Proper morphisms for family of functions, Vadim Zaliva, 01/06/2016
- Re: [Coq-Club] Proper morphisms for family of functions, Abhishek Anand, 01/06/2016
- Re: [Coq-Club] Proper morphisms for family of functions, Abhishek Anand, 01/08/2016
