- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proper morphisms for family of functions
- Date: Tue, 5 Jan 2016 22:08:11 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vadim.zaliva AT west.cmu.edu; spf=None smtp.mailfrom=vadim.zaliva AT west.cmu.edu; spf=None smtp.helo=postmaster AT mail-oi0-f41.google.com
- Ironport-phdr: 9a23:KzzdsxLOe2u9N5S7atmcpTZWNBhigK39O0sv0rFitYgUKPnxwZ3uMQTl6Ol3ixeRBMOAu6wC07KempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lRMiK14ye7KObxd76W01wnj2zYLd/fl2djD76kY0ou7ZkMbs70RDTo3FFKKx8zGJsIk+PzV6nvp/jtM0rzyMFsPU4ssVETK/SfqIiTLUeAi51HXoy4ZjVvBXCSEO9738dTGxexgRaCgzE8hjSVZLs9Cb2q7wui2GhIcTqQOVsCnyZ5KBxRUqwhQ==
On Jan 5, 2016, at 21:46 , Abhishek Anand <abhishek.anand.iitg AT gmail.com> wrote:Sorry, I forgot that I had to make another fix to your code.
Thanks! That was it. Now about your other suggestion:
1) Take a look at MathClasses.theory.setoids.ext_equiv_reflMoreover, you might want to reuse MathClasses.interfaces.abstract_algebra.Setoid_Morphism instead of defining your own `O`.
That was also super helpful! I still want to have my own class but I just defined it as:
Class O (op: A -> A) :=
o_setoidmor :> Setoid_Morphism op.
and if I use `apply ext_equiv_refl` instead of `reflexivity` everything works just great. Here is full example: http://ideone.com/rbD6rv reworked per your suggestions.
However I am still wondering if there is a way to declare such refined/specialized instance of ‘Reflexive’ for Setoid_Morphisms so
reflexivity tactics would work as well?
Sincerely,
Vadim Zaliva
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
- Re: [Coq-Club] Proper morphisms for family of functions, Gregory Malecha, 01/01/2016
- Re: [Coq-Club] Proper morphisms for family of functions, Vadim Zaliva, 01/01/2016
- <Possible follow-up(s)>
- Re: [Coq-Club] Proper morphisms for family of functions, Vadim Zaliva, 01/06/2016
- Re: [Coq-Club] Proper morphisms for family of functions, Abhishek Anand, 01/06/2016
- Re: [Coq-Club] Proper morphisms for family of functions, Abhishek Anand, 01/08/2016
