- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq 8.5 is out!
- Date: Fri, 22 Jan 2016 07:09:47 +0100
Hello. Unfortunately, with the development version of CoLoR for 8.5 (http://rewriting.gforge.inria.fr/divers/color8.5rc1.tar.gz), I get two bugs:
07:00 ~/src/color-svn-8.5 make -j20 -k
make -r -f Makefile.coq
make[1]: entrant dans le répertoire « /local/blanqui/src/color-svn-8.5 »
"coqc" -q -R "." CoLoR Util/FMap/FMapUtil
"coqc" -q -R "." CoLoR Util/Relation/Tarski
File "./Util/Relation/Tarski.v", line 99, characters 4-92:
Anomaly: File "pretyping/indrec.ml", line 169, characters 14-20: Assertion failed.
Please report.
make[1]: *** [Util/Relation/Tarski.vo] Erreur 129
File "./Util/FMap/FMapUtil.v", line 808, characters 0-9:
Anomaly: Uncaught exception Not_found. Please report.
make[1]: *** [Util/FMap/FMapUtil.vo] Erreur 129
make[1]: La cible « all » n'a pas pu être refabriquée à cause d'erreurs.
make[1]: quittant le répertoire « /local/blanqui/src/color-svn-8.5 »
make: *** [default] Erreur 2
I filled the corresponding bug reports:
https://coq.inria.fr/bugs/show_bug.cgi?id=4506
https://coq.inria.fr/bugs/show_bug.cgi?id=4505
Le 22/01/2016 01:22, Maxime Dénès a écrit :
Dear Coq-Clubers,
The Coq development team is pleased to announce the final release
of Coq 8.5 available at:
http://coq.inria.fr/coq-85
This release includes many bug fixes with respect to the previous
versions, and a few incompatible changes, see the following file for
more information:
https://coq.inria.fr/distrib/V8.5/CHANGES
Source, Windows and OS X packages are available.
We recall the new available features of version 8.5:
- asynchronous edition of documents under CoqIDE to keep working on a
proof while Coq checks the other proofs in the background (by Enrico
Tassi);
- universe polymorphism making it possible to reuse the same
definitions at various universe levels (by Matthieu Sozeau);
- primitive projections improving space and time efficiency of
records, and adding eta-conversion for records (by Matthieu Sozeau);
- extensions of the new proof engine featuring dependent subgoals
management, fully backtracking tactics, as well as tactics which can
consider multiple goals together (by Arnaud Spiwack);
- a new reduction procedure called native_compute to evaluate terms
using the OCaml native compiler, for proofs with large computational
steps (by Maxime Dénès).
The main other changes are:
- a new fast compilation chain that skips checking of proofs (producing
.vio files);
- a new construct ltac:(..) to call tactics from term definitions;
- a more restrictive guard condition to recover compatibility with axioms
like propositional extensionality and (some consequences of) univalence;
- a new option -type-in-type to collapse the universe hierarchy (makes
the logic inconsistent but useful for exploration);
- a better-behaved alternative to simpl, called cbn;
- various improvements to the tactic language, like a new introduction
pattern [= x1 ... xn] which applies injection on the fly (inspired
by SSReflect); new constructs uconstr:c and type_term c to build
untyped terms in Ltac;
- significant improvements of general efficiency.
See http://coq.inria.fr/ for more details, and the CHANGES file in the
distribution for a comprehensive list.
The Coq development team wishes to acknowledge the many
people who made Coq 8.5 possible: Pierre Boutillier,
Pierre Courtieu, Maxime Dénès, Hugo Herbelin, Pierre Letouzey,
Pierre-Marie Pédrot, Yann Régis-Gianas, Matthieu Sozeau, Arnaud
Spiwack, Enrico Tassi with contributions also from Bruno Barras, Yves
Bertot, Frédéric Besson, Xavier Clerc, Pierre Corbineau,
Jean-Christophe Filliâtre, Julien Forest, Sébastien Hinderer, Assia
Mahboubi, Guillaume Melquiond, Jean-Marc Notin, François Ripault,
Carst Tankink as well as many external contributors.
The Coq Development Team
- [Coq-Club] Coq 8.5 is out!, Maxime Dénès, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, John Wiegley, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Frédéric Blanqui, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Hugo Herbelin, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Maxime Dénès, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Frédéric Blanqui, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Guillaume Melquiond, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Enrico Tassi, 01/25/2016
