- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq 8.5 is out!
- Date: Mon, 25 Jan 2016 11:22:07 +0100
Hello Enrico.
I was just trying to use your new compilation procedure but I get errors. But I am not sure how to proceed. It's perhaps better to discuss this offline first.
time make -j20 quick:
Error: The value you are asking for (matching_complete) is not available in
this process. If you really need this, pass the "-async-proofs off" option to
CoqIDE to disable asynchronous script processing and don't pass "-quick" to
coqc.
make[1]: *** [Conversion/Coccinelle.vio] Erreur 1
make[1]: *** Attente des tâches non terminées....
make[1]: quittant le répertoire « /local/blanqui/src/color-svn-8.5 »
make: *** [quick] Erreur 2
real 3m2.226s
user 20m31.229s
sys 1m50.994s
Note that I do not use CoqIDE. It's batch compilation.
Frédéric.
Le 25/01/2016 11:15, Enrico Tassi a écrit :
On Mon, Jan 25, 2016 at 11:08:33AM +0100, Frédéric Blanqui wrote:
j |Can you try with a -j6 when you have a minute?
1 | 27'00"
3 | 10'47"
20| 6'45"
So, you can see that it is really important for me to use -j20...
Also, given that you mentioned it, do you have timings for
"make quick -j20" and "make vio2vo J=20" ?
Best,
- [Coq-Club] Coq 8.5 is out!, Maxime Dénès, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, John Wiegley, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Frédéric Blanqui, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Hugo Herbelin, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Maxime Dénès, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Frédéric Blanqui, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Guillaume Melquiond, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Enrico Tassi, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Jacques-Henri Jourdan, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Pierre-Marie Pédrot, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Emilio Jesús Gallego Arias, 01/25/2016
