- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq 8.5 is out!
- Date: Fri, 22 Jan 2016 15:37:18 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT maximedenes.fr; spf=Pass smtp.mailfrom=mail AT maximedenes.fr; spf=None smtp.helo=postmaster AT 4.mo6.mail-out.ovh.net
- Ironport-phdr: 9a23:zau3LRWrQix1aX3WJCn25WzfayvV8LGtZVwlr6E/grcLSJyIuqrYZheAt8tkgFKBZ4jH8fUM07OQ6PC+HzVYvN3f7DgrS99laVwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oM2NJVwQ2XHjPftbF1afk0b4joEum4xsK6I8mFPig0BjXKBo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN/dwcbsNBzM/dmsx+cfDtB/ZTALJ6GFPfH8Rl09tChjE6Ryychb3MjCy4u902S2yOMTmTLU5VTmk4rwtRgW+23RPDCIw7GyC0p84t6lcuh/0/xE=
Hello Frédéric,
Thanks for the feedback!
I'd like to seize the opportunity to recall a few things about the Coq development process:
- no Coq release is claimed or expected to be bug free
- bugs reported *early* in the release cycle are *more likely* to be fixed in the next release
- we follow the bug tracker very closely, so there is in general no need to repeat reports on Coq-club
The beta phase of Coq 8.5 lasted close to a year, with a lot of bugs fixed, so we hope that the final version will provide a good user experience. However, we also hope to see Coq users quickly contribute bug reports on 8.5, so that we can provide, as Hugo said, a patch level release that will make the user experience even better!
Best,
Maxime.
On 01/22/16 12:17, Hugo Herbelin wrote:
Dear Frédéric,
I"m very sorry for this bad experience you encountered. I understand
your frustration to see 8.5 released just one day after you submitting
two bugs which are blocking for you, but the release process of 8.5
final was already started when you submitted your bugs.
About your bug #4506, note that it is not specific to 8.5. It is
reproducible in former versions, including e.g. 8.5rc1, and even
already 8.0. It can be circumvented by using "Unset Elimination
Schemes.", but congratulation for having found it.
About your bug #4605, it would require more inspection. I'm travelling
today while other developers are at POPL and other teaching at a
winter school, all having given a lot for this release, but be sure
that we will take care of your bug by the next patch level release.
Best regards,
Hugo
On Fri, Jan 22, 2016 at 07:09:47AM +0100, Frédéric Blanqui wrote:
Hello. Unfortunately, with the development version of CoLoR for 8.5
(http://rewriting.gforge.inria.fr/divers/color8.5rc1.tar.gz), I get
two bugs:
07:00 ~/src/color-svn-8.5 make -j20 -k
make -r -f Makefile.coq
make[1]: entrant dans le répertoire « /local/blanqui/src/color-svn-8.5 »
"coqc" -q -R "." CoLoR Util/FMap/FMapUtil
"coqc" -q -R "." CoLoR Util/Relation/Tarski
File "./Util/Relation/Tarski.v", line 99, characters 4-92:
Anomaly: File "pretyping/indrec.ml", line 169, characters 14-20:
Assertion failed.
Please report.
make[1]: *** [Util/Relation/Tarski.vo] Erreur 129
File "./Util/FMap/FMapUtil.v", line 808, characters 0-9:
Anomaly: Uncaught exception Not_found. Please report.
make[1]: *** [Util/FMap/FMapUtil.vo] Erreur 129
make[1]: La cible « all » n'a pas pu être refabriquée à cause d'erreurs.
make[1]: quittant le répertoire « /local/blanqui/src/color-svn-8.5 »
make: *** [default] Erreur 2
I filled the corresponding bug reports:
https://coq.inria.fr/bugs/show_bug.cgi?id=4506
https://coq.inria.fr/bugs/show_bug.cgi?id=4505
Le 22/01/2016 01:22, Maxime Dénès a écrit :
Dear Coq-Clubers,
The Coq development team is pleased to announce the final release
of Coq 8.5 available at:
http://coq.inria.fr/coq-85
This release includes many bug fixes with respect to the previous
versions, and a few incompatible changes, see the following file for
more information:
https://coq.inria.fr/distrib/V8.5/CHANGES
Source, Windows and OS X packages are available.
We recall the new available features of version 8.5:
- asynchronous edition of documents under CoqIDE to keep working on a
proof while Coq checks the other proofs in the background (by Enrico
Tassi);
- universe polymorphism making it possible to reuse the same
definitions at various universe levels (by Matthieu Sozeau);
- primitive projections improving space and time efficiency of
records, and adding eta-conversion for records (by Matthieu Sozeau);
- extensions of the new proof engine featuring dependent subgoals
management, fully backtracking tactics, as well as tactics which can
consider multiple goals together (by Arnaud Spiwack);
- a new reduction procedure called native_compute to evaluate terms
using the OCaml native compiler, for proofs with large computational
steps (by Maxime Dénès).
The main other changes are:
- a new fast compilation chain that skips checking of proofs (producing
.vio files);
- a new construct ltac:(..) to call tactics from term definitions;
- a more restrictive guard condition to recover compatibility with axioms
like propositional extensionality and (some consequences of)
univalence;
- a new option -type-in-type to collapse the universe hierarchy (makes
the logic inconsistent but useful for exploration);
- a better-behaved alternative to simpl, called cbn;
- various improvements to the tactic language, like a new introduction
pattern [= x1 ... xn] which applies injection on the fly (inspired
by SSReflect); new constructs uconstr:c and type_term c to build
untyped terms in Ltac;
- significant improvements of general efficiency.
Seehttp://coq.inria.fr/ for more details, and the CHANGES file in the
distribution for a comprehensive list.
The Coq development team wishes to acknowledge the many
people who made Coq 8.5 possible: Pierre Boutillier,
Pierre Courtieu, Maxime Dénès, Hugo Herbelin, Pierre Letouzey,
Pierre-Marie Pédrot, Yann Régis-Gianas, Matthieu Sozeau, Arnaud
Spiwack, Enrico Tassi with contributions also from Bruno Barras, Yves
Bertot, Frédéric Besson, Xavier Clerc, Pierre Corbineau,
Jean-Christophe Filliâtre, Julien Forest, Sébastien Hinderer, Assia
Mahboubi, Guillaume Melquiond, Jean-Marc Notin, François Ripault,
Carst Tankink as well as many external contributors.
The Coq Development Team
- [Coq-Club] Coq 8.5 is out!, Maxime Dénès, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, John Wiegley, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Frédéric Blanqui, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Hugo Herbelin, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Maxime Dénès, 01/22/2016
- Re: [Coq-Club] Coq 8.5 is out!, Frédéric Blanqui, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Guillaume Melquiond, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Enrico Tassi, 01/25/2016
