coq-club - RE: [Coq-Club] how to run this program to verify a simple function?
  • To: John Wiegley <johnw AT newartisans.com>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] how to run this program to verify a simple function?
  • Date: Sat, 23 Jan 2016 09:56:33 +0800
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tesleft AT hotmail.com; spf=Pass smtp.mailfrom=tesleft AT hotmail.com; spf=None smtp.helo=postmaster AT BLU004-OMC4S4.hotmail.com
  • Importance: Normal
  • Ironport-phdr: 9a23:mjjF5Beq0r+57vhqTbGeMxQQlGMj4u6mDksu8pMizoh2WeGdxc69bR7h7PlgxGXEQZ/co6odzbGG7ea5ATJLusbJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvipduKO1sD32r1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu3SNp41Rr1ADTkgL3t9pIiy7UGCHkOz4S4+VWUQ2iVJDgfB4QCyCpX2si3lnuxwxyCAIcztRLYvHz+l6vE4ZgXvjXIiPjg14Snyg9ZsjaRc6Ea9qgd7zoDISIGSKP93f6ebdtQfEzkSFv1NXjBMV9vvJ7AECPAMaKMB99Hw
Hi John,
there  are  many  errors  when i run  this  though  solved  by  import  ZArith.
martin@ubuntu:~/hilbertreborn$ coqtop
Welcome to Coq 8.4pl6 (December 2015)
Coq < Require Import ZArith.
Inductive tree : Set :=
| Empty
| Node : tree -> Z -> tree -> tree.
Inductive In (x:Z) : tree -> Prop :=
| In_left : forall l r y, (In x l) -> (In x (Node l y r))
| In_right : forall l r y, (In x r) -> (In x (Node l y r))
| Is_root : forall l r, (In x (Node l x r)).
Definition is_empty (s:tree) : bool := match s with
| Empty => true
| _ => false end.
Theorem is_empty_correct :
forall s, (is_empty s)=true <-> (forall x, ~(In x s)).
Proof.
destruct s; simpl; intuition.
inversion_clear H0.
elim H with z; auto.
Qed.
Inductive order : Set := Lt | Eq | Gt.
Hypothesis compare : Z -> Z -> order.
Fixpoint mem (x:Z) (s:tree) {struct s} : bool := match s with
| Empty =>
   false
| Node l y r => match compare x y with
   | Lt => mem x l
   | Eq => true
   | Gt => mem x r
  end
end.
Inductive bst : tree -> Prop :=
| bst_empty :
   (bst Empty)
| bst_node :
   forall x (l r : tree),
   bst l -> bst r ->
   (forall y, In y l -> y < x) ->
   (forall y, In y r -> x < y) -> bst (Node l x r).
Theorem mem_correct :
  forall x s, (bst s) -> (mem x s=true <-> In x s).
Hypothesis compare_spec :
  forall x y, match compare x y with
  | Lt => x<y
  | Eq => x=y
  | Gt => x>y
  end.
generalize (compare_spec x z); destruct (compare x z).[Loading ML file z_syntax_plugin.cmxs ... done]
[Loading ML file quote_plugin.cmxs ... done]
[Loading ML file newring_plugin.cmxs ... done]
[Loading ML file omega_plugin.cmxs ... done]
Coq < Coq < Coq < Coq < tree is defined
tree_rect is defined
tree_ind is defined
tree_rec is defined
Coq < Coq < Coq < Coq < Coq < In is defined
In_ind is defined
Coq < Coq < Coq < Coq < is_empty is defined
Coq < Coq < Coq < 1 subgoal
   forall s : tree, is_empty s = true <-> (forall x : Z, ~ In x s)
is_empty_correct < 1 subgoal
is_empty_correct < 2 subgoals
  H : true = true
  x : Z
  H0 : In x Empty
   False
subgoal 2 is:
 false = true
  s1 : tree
  z : Z
  s2 : tree
  H : forall x : Z, In x (Node s1 z s2) -> False
   false = true
  s1 : tree
  z : Z
  s2 : tree
   In z (Node s1 z s2)
is_empty_correct < destruct s; simpl; intuition.
 inversion_clear H0.
Error: Attempt to save an incomplete proof
is_empty_correct < is_empty_correct < order is defined
order_rect is defined
order_ind is defined
order_rec is defined
is_empty_correct < is_empty_correct < compare is assumed
Warning: compare is declared as a parameter because it is at a global level
is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < mem is recursively defined (decreasing on 2nd argument)
is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < Toplevel input, characters 149-150:
Error: In environment
bst : tree -> Prop
x : ?177
l : tree
r : tree
y : Z
The term "y" has type "Z" while it is expected to have type
"nat".
is_empty_correct < is_empty_correct < is_empty_correct < Toplevel input, characters 39-42:
Error: The reference bst was not found in the current environment.
is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < is_empty_correct < Toplevel input, characters 74-75:
>   | Lt => x<y
x : Z
y : Z
The term "x" has type "Z" while it is expected to have type
"nat".
is_empty_correct < is_empty_correct < Toplevel input, characters 13-25:
Error: The reference compare_spec was not found in the current environment.
is_empty_correct <
Regards,
Martin
To: johnw AT newartisans.com
CC: coq-club AT inria.fr
Date: Sat, 23 Jan 2016 09:50:24 +0800
Hi  ,
when i continue to run,  got  some  error
Coq < Coq < Coq < Coq < Error: tree already exists.
Coq < Inductive In (x:Z) : tree -> Prop :=
| Empty => true
| _ => false end.Coq < Coq < Coq < Toplevel input, characters 192-193:
In : Z -> tree -> Prop
x : Z
l : tree
r : ?8
"tree".
Regards,
Martin
> From: johnw AT newartisans.com
> To: tesleft AT hotmail.com
> Subject: Re: [Coq-Club] how to run this program to verify a simple function?
> Date: Fri, 22 Jan 2016 17:48:17 -0800
> >>>>> Mandy Martino <tesleft AT hotmail.com> writes:
> > Error: The reference Z was not found in the current environment.
> I'm not sure whether the course defines Z some place, but otherwise you should
> just need:
> John Wiegley GPG fingerprint = 4710 CF98 AF9B 327B B80F
> http://newartisans.com 60E1 46C4 BD1A 7AC1 4BA2
