coq-club - RE: [Coq-Club] how to run this program to verify a simple function?
  • To: John Wiegley <johnw AT newartisans.com>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] how to run this program to verify a simple function?
  • Date: Sat, 23 Jan 2016 11:26:58 +0800
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tesleft AT hotmail.com; spf=Pass smtp.mailfrom=tesleft AT hotmail.com; spf=None smtp.helo=postmaster AT BLU004-OMC4S30.hotmail.com
  • Importance: Normal
  • Ironport-phdr: 9a23:VYJ/RBLZHZhS+YUKwtmcpTZWNBhigK39O0sv0rFitYgULfXxwZ3uMQTl6Ol3ixeRBMOAu6wC0rKI+P2xEUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35rxjrjssMCCKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46Fp34d6XK77Z6U1S6BDRHRjajhtpZ6jiR6WbwyP4DMjU2gZlhdZS1zH6xH8Qb/3vzTzrPZ8wyCcJov9SrViChq46KI+bRbuhDZPEjcj7GDRjYQkkK9ApB+vuzR/xJLRaYCRcvF5e/WOLpshWWNdU5MJBGR6CYSmYt5KVrJZMA==
Hi John,
martin@ubuntu:~/hilbertreborn$ ocaml -version
The Objective Caml toplevel, version 3.12.1
i have  already been using  3.12.1,  why  still have  error?
Regards,
Martin
To: johnw AT newartisans.com
CC: coq-club AT inria.fr
Date: Sat, 23 Jan 2016 10:56:13 +0800
Hi  ,
it  use  version 8.0
after downloaded,  i  discover  that  in ubuntu 12  i installed  version  8.4  before,  i do not  know  how to uninstall  this  which  using configure to install
i  continue to  configure  8.0  and  make world, got  error
martin@ubuntu:~/hilbertreborn/coq-8.0pl3$ make world
OCAMLC    config/coq_config.mli
ECHO... > scripts/tolink.ml
OCAMLC    scripts/tolink.ml
OCAMLC    scripts/coqmktop.ml
File "scripts/coqmktop.ml", line 233, characters 8-11:
Warning 26: unused variable stg.
OCAMLC -o bin/coqmktop
OCAMLOPT  config/coq_config.ml
OCAMLC    lib/pp_control.mli
OCAMLOPT  lib/pp_control.ml
OCAMLC    lib/pp.mli
OCAMLOPT4 lib/pp.ml4
Camlp4: Uncaught exception: DynLoader.Error ("pa_ifdef.cmo", "file not found in path")
File "lib/pp.ml4", line 1, characters 0-1:
Error: Preprocessor error
make: *** [lib/pp.cmx] Error 2
Regards,
Martin
> From: johnw AT newartisans.com
> To: tesleft AT hotmail.com
> Subject: Re: [Coq-Club] how to run this program to verify a simple function?
> Date: Fri, 22 Jan 2016 18:16:18 -0800
> >>>>> Mandy Martino <tesleft AT hotmail.com> writes:
> > is_empty_correct < destruct s; simpl; intuition.
> > inversion_clear H0.
> > elim H with z; auto.
> > Error: Attempt to save an incomplete proof
> Are you using the right version of Coq for this material? There seem to be a
> lot of things going on, and I'm not sure what the underlying problem is from
> this distance..
> John Wiegley GPG fingerprint = 4710 CF98 AF9B 327B B80F
> http://newartisans.com 60E1 46C4 BD1A 7AC1 4BA2
