- To: John Wiegley <johnw AT newartisans.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] how to run this program to verify a simple function?
- Date: Sun, 24 Jan 2016 02:29:36 +0000
- Accept-language: zh-HK, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tesleft AT hotmail.com; spf=Pass smtp.mailfrom=tesleft AT hotmail.com; spf=None smtp.helo=postmaster AT BAY004-OMC1S11.hotmail.com
- Ironport-phdr: 9a23:2DfrvRAfui+ycYMrCScfUyQJP3N1i/DPJgcQr6AfoPdwSP7zpsbcNUDSrc9gkEXOFd2CrakU1ayP6/+rAzRdqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh770osWMKF8Q2XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGY2zRakzTKRZATI6KCh1oZSz7ViQBTeIs1kbUmNerRtFDAzI/VmuXJDxtDTSsOdi0TOGPNb/S6tyUjOnufRFUhjt3QIOMTIouETekNBxiqUT9A6svBhyzZL8YIaJMfN/euXWetZMFjkJZdpYSyEUWtD0VIAIFedUeL8A94Q=
Hi John,
in ubuntu 12 virtual machine using ocqml 3.12.1 but install coq 8.0 got error
as stated before.
in ubuntu 14, have 8.4pl6 , have error , so i change to ubuntu 12 machine ,
then have installation error for coq 8.0.
martin@ubuntu:~$ ocaml -version
The OCaml toplevel, version 4.01.0
martin@ubuntu:~$ coqc -version
coqc: -version: no such file or directory
martin@ubuntu:~$ coqc --version
The Coq Proof Assistant, version 8.4pl6 (December 2015)
compiled on Dec 18 2015 23:12:11 with OCaml 4.01.0
martin@ubuntu:~$
Error: In environment
x : Z
y : Z
The term "x" has type "Z" while it is expected to have type
"nat".
is_empty_correct < is_empty_correct < Toplevel input, characters 13-25:
> generalize (compare_spec x z); destruct (compare x z).
Error: The reference compare_spec was not found in the current environment.
is_empty_correct <
Regards,
Martin
________________________________________
寄件者: John Wiegley
<jwiegley AT gmail.com>
代表 John Wiegley
寄件日期: 2016年1月24日 3:58
收件者: Mandy Martino
副本:
主旨: Re: [Coq-Club] how to run this program to verify a simple function?
>>>>> Mandy Martino
>>>>> <tesleft AT hotmail.com>
>>>>> writes:
> i have already been using 3.12.1, why still have error?
I'm not sure, but 3.12 and Coq 8.0 are very old versions. Is there any way to
upgrade to OCaml 4 and Coq 8.4pl6? Then I could try your code here, if it is
available online anywhere.
John Wiegley GPG fingerprint = 4710 CF98 AF9B 327B B80F
http://newartisans.com 60E1 46C4 BD1A 7AC1 4BA2
- [Coq-Club] how to run this program to verify a simple function?, Mandy Martino, 01/23/2016
- Re: [Coq-Club] how to run this program to verify a simple function?, John Wiegley, 01/23/2016
- RE: [Coq-Club] how to run this program to verify a simple function?, Mandy Martino, 01/23/2016
- RE: [Coq-Club] how to run this program to verify a simple function?, Mandy Martino, 01/24/2016
- Re: [Coq-Club] how to run this program to verify a simple function?, Adam Chlipala, 01/24/2016
