coq-club - Re: [Coq-Club] Coq 8.5 is out!
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq 8.5 is out!
  • Date: Tue, 26 Jan 2016 17:11:02 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mail AT maximedenes.fr; spf=Pass smtp.mailfrom=mail AT maximedenes.fr; spf=None smtp.helo=postmaster AT 3.mo5.mail-out.ovh.net
  • Ironport-phdr: 9a23:Xvi4/xZv/Kcb2t6rbOE1ZpL/LSx+4OfEezUN459isYplN5qZpc+/bnLW6fgltlLVR4KTs6sC0LqJ9fi4EjJaqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7/0o8WYPV8ArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq8/VPlTCCksG2Ez/szi8xfZHiWV4X5Jd2wGkx9FSyRE6pHhFsP0uyr+nu90yCifMMH7S70vHzq4ufQ4ACT0gTsKYmZquFrcjdZ92fpW
Separate compilation for native_compute is disabled by default. So unless you actually use native_compute (or pass the -native-compiler flag to coqc), it should not have any performance impact.
Maxime.
On 01/26/16 14:29, Jacques-Henri Jourdan wrote:
Another guess : it seems like most of the overhead is spent on IO. Have
you tried to deactivate native compilation, that can lead to quite a lot
of IOs ?
Le 26/01/2016 13:41, Pierre-Marie Pédrot a écrit :
On 26/01/2016 09:19, Frédéric Blanqui wrote:
I tried Jacques-Henri's patch and, indeed, I get a total compilation
time similar to the one of Coq 8.4pl6:
That's still somehow bad, because as 8.5 already should be quicker than
8.4, the universe patch should therefore really speed things up. It
means we have a complexity regression somewhere, although it may be
quite diffuse.
PMP
