- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq 8.5 is out!
- Date: Fri, 22 Jan 2016 10:52:33 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:7Sxy2h9ZXYeuXf9uRHKM819IXTAuvvDOBiVQ1KB91+0cTK2v8tzYMVDF4r011RmSDdudsqoZwLWH+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStCU1pzqnL/js7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGCCLZ34RVHkhqhtURk3u6BjnUpr1+n/xsud41S+Ge9X3UZg7XD2j6+FgTxq+23RPDCIw7GyC0p84t6lcuh/0/xE=
Hi Maxime and coq-club,
Congratulation to everyone who contributed to this release! It's great to see
Coq making quick progress.
Cheers,
Clément.
On 01/21/2016 07:22 PM, Maxime Dénès wrote:
> Dear Coq-Clubers,
> The Coq development team is pleased to announce the final release
> of Coq 8.5 available at:
> http://coq.inria.fr/coq-85
> This release includes many bug fixes with respect to the previous
> versions, and a few incompatible changes, see the following file for
> more information:
> https://coq.inria.fr/distrib/V8.5/CHANGES
> Source, Windows and OS X packages are available.
> We recall the new available features of version 8.5:
> - asynchronous edition of documents under CoqIDE to keep working on a
> proof while Coq checks the other proofs in the background (by Enrico
> Tassi);
> - universe polymorphism making it possible to reuse the same
> definitions at various universe levels (by Matthieu Sozeau);
> - primitive projections improving space and time efficiency of
> records, and adding eta-conversion for records (by Matthieu Sozeau);
> - extensions of the new proof engine featuring dependent subgoals
> management, fully backtracking tactics, as well as tactics which can
> consider multiple goals together (by Arnaud Spiwack);
> - a new reduction procedure called native_compute to evaluate terms
> using the OCaml native compiler, for proofs with large computational
> steps (by Maxime Dénès).
> The main other changes are:
> - a new fast compilation chain that skips checking of proofs (producing
> .vio files);
> - a new construct ltac:(..) to call tactics from term definitions;
> - a more restrictive guard condition to recover compatibility with axioms
> like propositional extensionality and (some consequences of) univalence;
> - a new option -type-in-type to collapse the universe hierarchy (makes
> the logic inconsistent but useful for exploration);
> - a better-behaved alternative to simpl, called cbn;
> - various improvements to the tactic language, like a new introduction
> pattern [= x1 ... xn] which applies injection on the fly (inspired
> by SSReflect); new constructs uconstr:c and type_term c to build
> untyped terms in Ltac;
> - significant improvements of general efficiency.
> See http://coq.inria.fr/ for more details, and the CHANGES file in the
> distribution for a comprehensive list.
> The Coq development team wishes to acknowledge the many
> people who made Coq 8.5 possible: Pierre Boutillier,
> Pierre Courtieu, Maxime Dénès, Hugo Herbelin, Pierre Letouzey,
> Pierre-Marie Pédrot, Yann Régis-Gianas, Matthieu Sozeau, Arnaud
> Spiwack, Enrico Tassi with contributions also from Bruno Barras, Yves
> Bertot, Frédéric Besson, Xavier Clerc, Pierre Corbineau,
> Jean-Christophe Filliâtre, Julien Forest, Sébastien Hinderer, Assia
> Mahboubi, Guillaume Melquiond, Jean-Marc Notin, François Ripault,
> Carst Tankink as well as many external contributors.
> The Coq Development Team
signature.asc
Description: OpenPGP digital signature
- Re: [Coq-Club] Coq 8.5 is out!, (continued)
- Re: [Coq-Club] Coq 8.5 is out!, Frédéric Blanqui, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Guillaume Melquiond, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Jacques-Henri Jourdan, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Pierre-Marie Pédrot, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Emilio Jesús Gallego Arias, 01/25/2016
- Re: [Coq-Club] Coq 8.5 is out!, Frédéric Blanqui, 01/26/2016
- Re: [Coq-Club] Coq 8.5 is out!, Pierre-Marie Pédrot, 01/26/2016
- Re: [Coq-Club] Coq 8.5 is out!, Jacques-Henri Jourdan, 01/26/2016
- Re: [Coq-Club] Coq 8.5 is out!, Maxime Dénès, 01/26/2016
