coq-club - Re: [Coq-Club] Coq 8.5 is out!
  • From: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq 8.5 is out!
  • Date: Mon, 25 Jan 2016 14:16:46 +0100
Maybe this is due to the universe algorithm. Have you tried my patch
(included in trunk but not in 8.5 currently) ?
JH
Le 25/01/2016 14:00, Guillaume Melquiond a écrit :
> On 25/01/2016 13:49, Frédéric Blanqui wrote:
>> Hi!
>> To give you finer statistics (COQC=./time_coqc make && ./stat_time in
>> CoLoR):
>> files: 265, time: 2037s, mean: 7.69s
>> max: 124.71s (./Coccinelle/term_orderings/rpo.v)
>> files>10s: 49 (18%), time: 1327s (65%)
>> There are 265 files. The average time is 7.69s/file. 49 files (18%) take
>> more than 10s each and 65% of the total time.
>> The record is Coccinelle/term_orderings/rpo.v (not actually part of
>> CoLoR but included in it for some reasons [the coq-color opam package
>> does not include it though]) with 124.71s! (It has 312136 characters and
>> 8259 lines.)
>> The 10 first files are:
>> ./Coccinelle/term_orderings/rpo.v 124,71
>> ./Term/Lambda/LAlpha.v 111,53
>> ./Term/Lambda/LCompClos.v 92,29
>> ./Term/Lambda/LSubs.v 77,31
>> ./Util/FGraph/FGraph.v 68,79
>> ./Term/Lambda/LCompRewrite.v 58,2
>> ./Term/Lambda/LComp.v 46,56
>> ./Util/FGraph/TransClos.v 45,47
>> ./Term/Lambda/LAlphaAlt.v 44,52
>> ./Term/SimpleType/TermsConv.v 29,64
>> With Coq 8.4pl6, the results are:
>> mean: 6.90s
>> max: 79.49s (./Coccinelle/term_orderings/rpo.v)
>> files>10s: 44 (16%), time: 980s (53%)
>> ./Coccinelle/term_orderings/rpo.v 79,49
>> ./Term/Lambda/LAlpha.v 62,11
>> ./Term/Lambda/LSubs.v 58,5
>> ./Term/Lambda/LCompClos.v 57,33
>> ./Term/SimpleType/TermsBeta.v 45,75
>> ./Util/FGraph/TransClos.v 37,3
>> ./Term/Lambda/LAlphaAlt.v 36,96
>> ./Term/Lambda/LCompRewrite.v 34,74
>> ./Util/FGraph/FGraph.v 29,83
>> ./Term/Lambda/LComp.v 29,19
>> So, on some files, the compilation time is multiplied by 2 almost... :-(
> Look at the bright side of it ;-). Since the overall time is only 60
> seconds larger, it also means that we are also doing incredibly better
> on many files. For instance, according to your numbers, TermsBeta is
> compiled at least 50% faster (if not more).
> That said, it would be interesting to know what makes rpo.v, LAlpha.v,
> and so on, so much slower to compile.
> Best regards,
> Guillaume
Attachment: signature.asc
Description: OpenPGP digital signature
