- From: Peter Vanderbilt <acm AT petervanderbilt.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top"
- Date: Wed, 10 Feb 2016 08:01:57 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=acm AT petervanderbilt.com; spf=None smtp.mailfrom=acm AT petervanderbilt.com; spf=None smtp.helo=postmaster AT se9.mailspamprotection.com
- Ironport-phdr: 9a23:ViP5QR+7B5oQsf9uRHKM819IXTAuvvDOBiVQ1KB91+kcTK2v8tzYMVDF4r011RmSDdqdsKgP27KempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lRciJ1Y/nj6ibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MlZFK7+Yq4QTLpCDT1gPXpmytfssEz7QBeC/DMiW2ManwBCAgzZpEXzVZLZqibmu/Bj0S+WMNf8TLQoHz+l6vE4G1fTlC4bOmthoynsgctqgfcDrQ==
Hi Clément,
Thanks for your response.
I strongly suspect that I need to get the flags ‘-R "." Top’ to coqtop, but I
don’t know how.
Does Proof General work for you using Coq8.5 with multiple files and “Require
Export”?
What do you have in your .emacs file for Coq and PG?
I don’t use a _CoqProject file. Would that help?
More details:
I’m using Version 4.2 of Proof General obtained via brew (Homebrew for Mac,
which is where I get Coq).
The Github PG you refer to is “version 4.2 (prerelease)”. Is that more or
less recent than what I have?
Its COMPATIBILITY file says, “This version of Proof General has been tested
with … (main) prover versions: Coq 8.3, Isabelle2011[-1]”.
Has it been tested with Coq 8.5?
I’m running Aquamacs 3.2 which is based on GNU Emacs 24.4.51.2. I get the
following message:
> Warning (emacs): Proof General compiled for GNU Emacs 24.2 but running on
> GNU Emacs 24.4: “make clean; make" is recommended.
However, I don’t know how to do what it suggests (given that it’s built by
brew).
I’ll see about trying the Github PG and/or coming up with a small example.
Pete
> On Feb 10, 2016, at 5:32 AM, Clément Pit--Claudel
> <clement.pit AT gmail.com>
> wrote:
> Which version of Proof General are you using? Does using the latest version
> at https://github.com/ProofGeneral/PG fix the problem? If not, can you
> raise an issue there with a small example?
> Clément.
> On 02/10/2016 05:23 AM, Frédéric Blanqui wrote:
>> Hello. I also raised this problem in
>> https://coq.inria.fr/bugs/show_bug.cgi?id=4541 .
>> Le 09/02/2016 19:55, Peter Vanderbilt a écrit :
>>> In Coq8.5, coq_makefile adds "-R . Top” to COQLIBS and COQDOCLIBS. Why?
>>> Doing so breaks coqtop in Emacs (Aquamacs), because the Require
>>> statements fail — it expects module “X” but gets “Top.X”.
>>> How do I get coq_makefile to not add "-R . Top” (as in 8.4)?
>>> OR
>>> How do I get the coqtop in emacs to have the right flags?
>>> Pete
- [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Peter Vanderbilt, 02/09/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Frédéric Blanqui, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Clément Pit--Claudel, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Peter Vanderbilt, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Peter Vanderbilt, 02/12/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Clément Pit--Claudel, 02/12/2016
- [Coq-Club] GitHub's ProofGeneral has old version number, Peter Vanderbilt, 02/13/2016
- Re: [Coq-Club] GitHub's ProofGeneral has old version number, Clément Pit--Claudel, 02/13/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Tej Chajed, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Christian Doczkal, 02/10/2016
