- From: Peter Vanderbilt <acm AT petervanderbilt.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top"
- Date: Thu, 11 Feb 2016 15:10:14 -0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=acm AT petervanderbilt.com; spf=None smtp.mailfrom=acm AT petervanderbilt.com; spf=None smtp.helo=postmaster AT delivery.mailspamprotection.com
- Ironport-phdr: 9a23:AxCfIRcTGjmv9d/JyD/duFbFlGMj4u6mDksu8pMizoh2WeGdxc6+YR7h7PlgxGXEQZ/co6odzbGG7Oa7BSdZuM7JmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvipNuIP04R3WL1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/zMztrxjKCwWVtVUGVWBDqhdUDhKN0hj8UprruCr+qqIp0SKfFdX7Ub0uRz2k46pxQh7slGEMMDtvozKfsdB5kK8O+EHpnBd42YOBOIw=
Hi Clément,
With the new README for PG on Github, I got it to compile and it works just
fine (with a newly crafted _CoqProject file).
Thanks.
Pete
> On Feb 10, 2016, at 9:21 AM, Clément Pit--Claudel
> <clement.pit AT gmail.com>
> wrote:
> Hi Pete,
> On 02/10/2016 11:01 AM, Peter Vanderbilt wrote:
>> I strongly suspect that I need to get the flags ‘-R "." Top’ to coqtop,
>> but I don’t know how.
> You could add this "-R Top" to the `coq-prog-args' variable, in a
> .dir-locals.el. But that's much more complicated than just adding a
> _CoqProject.
>> Does Proof General work for you using Coq8.5 with multiple files and
>> “Require Export”?
> Yes, it seems to work fine.
>> What do you have in your .emacs file for Coq and PG?
> (require 'proof-site "~/.emacs.d/lisp/PG/generic/proof-site")
> (I also have (add-hook 'coq-mode-hook #'company-coq-mode), but that's
> beyond PG)
>> I don’t use a _CoqProject file. Would that help?
> Yes, it should help. But not with the version of PG that you're currently
> using :)
>> More details:
>> I’m using Version 4.2 of Proof General obtained via brew (Homebrew for
>> Mac, which is where I get Coq).
> 4.2 dates back to October 2012. Pierre Courtieu has been actively
> maintaining the Coq part of it since then, but we don't have access to the
> website, so we can't update it. And I don't know who makes the homebrew
> packages either, so I'm not sure who to ask to update them.
>> The Github PG you refer to is “version 4.2 (prerelease)”. Is that more or
>> less recent than what I have?
>> Its COMPATIBILITY file says, “This version of Proof General has been
>> tested with … (main) prover versions: Coq 8.3, Isabelle2011[-1]”.
>> Has it been tested with Coq 8.5?
> Someone should have updated that file a long time ago; I just did. PG has
> been tested and updated to work with 8.5.
>> I’m running Aquamacs 3.2 which is based on GNU Emacs 24.4.51.2. I get the
>> following message:
>>> Warning (emacs): Proof General compiled for GNU Emacs 24.2 but running on
>>> GNU Emacs 24.4: “make clean; make" is recommended.
> Indeed, which is another reason why installing PG via homebrew is not
> recommended :)
>> However, I don’t know how to do what it suggests (given that it’s built by
>> brew).
>> I’ll see about trying the Github PG and/or coming up with a small example.
> Thanks!
> Clément.
- [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Peter Vanderbilt, 02/09/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Frédéric Blanqui, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Clément Pit--Claudel, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Peter Vanderbilt, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Peter Vanderbilt, 02/12/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Clément Pit--Claudel, 02/12/2016
- [Coq-Club] GitHub's ProofGeneral has old version number, Peter Vanderbilt, 02/13/2016
- Re: [Coq-Club] GitHub's ProofGeneral has old version number, Clément Pit--Claudel, 02/13/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Tej Chajed, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Christian Doczkal, 02/10/2016
