- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top"
- Date: Fri, 12 Feb 2016 08:07:37 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:m3AOXhEPuGa7e4FDdfDV8p1GYnF86YWxBRYc798ds5kLTJ75o8mwAkXT6L1XgUPTWs2DsrQf27WQ6P6rBTBIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niKbppdaPP01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y43VuQTnxxUNDDE8FS/dZP4ryf3sqIp0y2XOMDwUfYsWCiK4KJiSRuugyACYW1quFrLg9B92foI6CmqoAZyltbZ
Great!
On 02/11/2016 06:10 PM, Peter Vanderbilt wrote:
> Hi Clément,
> With the new README for PG on Github, I got it to compile and it works just
> fine (with a newly crafted _CoqProject file).
> Thanks.
> Pete
>> On Feb 10, 2016, at 9:21 AM, Clément Pit--Claudel
>> wrote:
>> Hi Pete,
>> On 02/10/2016 11:01 AM, Peter Vanderbilt wrote:
>>> I strongly suspect that I need to get the flags ‘-R "." Top’ to coqtop,
>>> but I don’t know how.
>> You could add this "-R Top" to the `coq-prog-args' variable, in a
>> .dir-locals.el. But that's much more complicated than just adding a
>> _CoqProject.
>>> Does Proof General work for you using Coq8.5 with multiple files and
>>> “Require Export”?
>> Yes, it seems to work fine.
>>> What do you have in your .emacs file for Coq and PG?
>> (require 'proof-site "~/.emacs.d/lisp/PG/generic/proof-site")
>> (I also have (add-hook 'coq-mode-hook #'company-coq-mode), but that's
>> beyond PG)
>>> I don’t use a _CoqProject file. Would that help?
>> Yes, it should help. But not with the version of PG that you're currently
>> using :)
>>> More details:
>>> I’m using Version 4.2 of Proof General obtained via brew (Homebrew for
>>> Mac, which is where I get Coq).
>> 4.2 dates back to October 2012. Pierre Courtieu has been actively
>> maintaining the Coq part of it since then, but we don't have access to the
>> website, so we can't update it. And I don't know who makes the homebrew
>> packages either, so I'm not sure who to ask to update them.
>>> The Github PG you refer to is “version 4.2 (prerelease)”. Is that more
>>> or less recent than what I have?
>>> Its COMPATIBILITY file says, “This version of Proof General has been
>>> tested with … (main) prover versions: Coq 8.3, Isabelle2011[-1]”.
>>> Has it been tested with Coq 8.5?
>> Someone should have updated that file a long time ago; I just did. PG has
>> been tested and updated to work with 8.5.
>>> I’m running Aquamacs 3.2 which is based on GNU Emacs 24.4.51.2. I get
>>> the following message:
>>>> Warning (emacs): Proof General compiled for GNU Emacs 24.2 but running
>>>> on GNU Emacs 24.4: “make clean; make" is recommended.
>> Indeed, which is another reason why installing PG via homebrew is not
>> recommended :)
>>> However, I don’t know how to do what it suggests (given that it’s built
>>> by brew).
>>> I’ll see about trying the Github PG and/or coming up with a small example.
>> Thanks!
>> Clément.
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Peter Vanderbilt, 02/09/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Frédéric Blanqui, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Clément Pit--Claudel, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Peter Vanderbilt, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Peter Vanderbilt, 02/12/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Clément Pit--Claudel, 02/12/2016
- [Coq-Club] GitHub's ProofGeneral has old version number, Peter Vanderbilt, 02/13/2016
- Re: [Coq-Club] GitHub's ProofGeneral has old version number, Clément Pit--Claudel, 02/13/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Tej Chajed, 02/10/2016
- Re: [Coq-Club] why does coq_makefile in 8.5 add "-R . Top", Christian Doczkal, 02/10/2016
