- From: "Terrell, Jeffrey" <jeffrey.terrell AT kcl.ac.uk>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coq-installer-8.5-win64.exe
- Date: Thu, 11 Feb 2016 15:58:24 +0000
- Accept-language: en-GB, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jeffrey.terrell AT kcl.ac.uk; spf=Pass smtp.mailfrom=jeffrey.terrell AT kcl.ac.uk; spf=Pass smtp.helo=postmaster AT EUR01-DB5-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23:5sAcqBQCBewSxMUM/pnE9nXfb9psv+yvbD5Q0YIujvd0So/mwa64Yh2N2/xhgRfzUJnB7Loc0qyN4/+mAjBLvsfJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvipNuIP04X1XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtB7dfFXEtN30/zMztrxjKCwWVrDNIWWIP1xFMHgLt7RfgX563vDGs5cRn3yzPd/H7V6o5XTDmp4VmRhHyhTZNf2o7/W/ZkMFhyr5WugisoxhXwIXQJoiecud9KPCONegGTHZMC54CHxdKBZmxOtMC
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:23
Hello Maxime,
That seems to have done the trick. I was given options to run or delete this time around as opposed to just delete last time. It’s worth noting that I’m not normally given an option to delete a download and so there’s still something slightly
amiss, but with what I’m not sure.
Anyway, I installed the release and it’s working fine. Thanks for your help.
Regards,
Jeff.
On 11 Feb 2016, at 13:33, Maxime Dénès <mail AT maximedenes.fr> wrote:
Hello,
I have just updated the Coq packages for Windows with a sha256 signature.
@Jeff Can you try again?
@Jérémy Thanks for pointing out the source of the problem.
Note that we may still get a "smartscreen" warning until Microsoft gets
more familiar with Coq 8.5 packages.
Maxime.
On 02/11/16 13:56, Jérémy Buisson wrote:
Hi,
A similar problem arose with VirtualBox:
https://forums.virtualbox.org/viewtopic.php?f=6&t=75851
MS has decided to reject SHA1 signatures:
https://technet.microsoft.com/library/security/3123479
Since the executable seems to be signed using SHA1 (according to my
system), it is rejected. It can still be forcibly executed, ignoring the
security advise.
Best.
*De :*coq-club-request AT inria.fr [mailto:coq-club-request AT inria.fr] *De
la part de* Jason Gross
*Envoyé :* jeudi 11 février 2016 13:39
*À :* Coq Club <coq-club AT inria.fr>
*Objet :* Re: [Coq-Club] coq-installer-8.5-win64.exe
This is a known bug, though the cause is not known. Tell it to run
anyway, or download the file on a browser that is not internet explorer.
On Thu, Feb 11, 2016, 7:34 AM Terrell, Jeffrey
<jeffrey.terrell AT kcl.ac.uk <mailto:jeffrey.terrell AT kcl.ac.uk>> wrote:
Hi,
I got the following error when I tried to download
coq-installer-8.5-win64.exe under Windows 8.1.
"The signature of this program is corrupt or invalid."
Any thoughts on what could be wrong?
Thanks.
Regards,
Jeff.
- [Coq-Club] coq-installer-8.5-win64.exe, Terrell, Jeffrey, 02/11/2016
- Re: [Coq-Club] coq-installer-8.5-win64.exe, Jason Gross, 02/11/2016
- RE: [Coq-Club] coq-installer-8.5-win64.exe, Jérémy Buisson, 02/11/2016
- Re: [Coq-Club] coq-installer-8.5-win64.exe, Maxime Dénès, 02/11/2016
- Re: [Coq-Club] coq-installer-8.5-win64.exe, Terrell, Jeffrey, 02/11/2016
- RE: [Coq-Club] coq-installer-8.5-win64.exe, Soegtrop, Michael, 02/11/2016
