coq-club - Re: [Coq-Club] Doubt about refine
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Doubt about refine
  • Date: Thu, 11 Feb 2016 10:08:56 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f48.google.com
  • Ironport-phdr: 9a23:K2ivTBey24seMg2XCgofo/c9lGMj4u6mDksu8pMizoh2WeGdxc65bR7h7PlgxGXEQZ/co6odzbGG7Oa7BSdevt6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDtvcaPKFsXzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OUg04tfqvF/NV1ih/HwZB0cRlBNUAwHDpDX3X4n8tDey4uh63iiZMMn7QJg7XD2j6+FgTxq+23RPDCIw7GyC0p84t6lcuh/0/xE=
On 02/11/2016 09:12 AM, Saulo Araujo wrote:
Hi Jonathan,
Thanks a lot for suggesting another technique. The resulting code is quite
pleasant and, at least to me, has one of the best signal to noise ratio :)
I never saw the character @ used as an operator. I looked in the Coq
reference manual and if, I understood it correctly, it disables the
inference of implicit parameters. Could you confirm if I understood it
correctly?
Sincerely,
Saulo
Yes, the "@" operator (which isn't technically an operator - it is instead built into the Gallina syntax as a identifier prefix character) makes all args explicit. However, it isn't really needed here, as the following get definition shows:
Fixpoint get E n (t: Sequence E n) (ds: List Digit n): E.
Proof.
refine(
match t with
| SequenceLeaf e0 e1 _ =>
match ds with
| ListLeaf D0 _ => e0
| ListLeaf D1 _ => e1
| ListNode _ _ _ => _
end
| SequenceNode s0 s1 _ =>
match ds with
| ListLeaf _ _ => _
| ListNode d _ _ =>
match d with
| D0 => get E _ s0 _
| D1 => get E _ s1 _
end
end
end
all:congruence.
Defined.
-- Jonathan
On Wed, Feb 10, 2016 at 9:50 PM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
There is another alternative. The type indexes can be omitted in favor of
extra equality fields. Doing this enables the use of basic matches in the
refine, as in the following rewriting of your example. No convoy patterns
are needed. I don't know why this technique isn't mentioned more
frequently.
Set Implicit Arguments.
Section Sequence.
Variable E: Set.
Inductive Sequence(n : nat) : Set :=
| SequenceLeaf: E -> E -> n=0 -> Sequence n
| SequenceNode: forall m, Sequence m -> Sequence m -> n = S m ->
Sequence n.
Inductive List(n : nat) : Set :=
| ListLeaf: E -> n=0 -> List n
| ListNode: forall m, E -> List m -> n = S m -> List n.
End Sequence.
Inductive Digit :=
| D0
| D1.
Proof.
refine(
match t with
| SequenceLeaf e0 e1 e =>
match ds with
| ListLeaf D0 _ => e0
| ListLeaf D1 _ => e1
| @ListNode _ _ y _ _ e2 => _
end
| @SequenceNode _ _ x s0 s1 _ =>
match ds with
| ListLeaf _ e0 => _
| @ListNode _ _ y d ds' _ =>
match d with
| D0 => get E x s0 _
| D1 => get E x s1 _
end
end
end
all:congruence.
Defined.
-- Jonathan
