- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Question about mutual inductive definition with fixpoint
- Date: Mon, 15 Feb 2016 23:39:02 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=ilmars.cirulis AT gmail.com; spf=Pass smtp.mailfrom=ilmars.cirulis AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f172.google.com
- Ironport-phdr: 9a23:gxcpsBNO/rd+ecw92XIl6mtUPXoX/o7sNwtQ0KIMzox0KPr9rarrMEGX3/hxlliBBdydsKIbzbaP+Pm9ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTokbzrsMSOO01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvNa8/VPlTCCksG2Ez/szi8xfZB0Pb7XwFF24SjxBgAg7f7Ri8UI2n4QXgse8o+S2fltftBZs1Qymm7rwjHB7sjS4dLHgy8XvKjs1rpK1eqROl4Rd4xtiHM8muKPNic/aFLpshTm1bU5MJWg==
There is much smaller toy example. I have to apologise about not minimizing it previously.
Let's take a list, that should contain only zeroes.| nil
| cons: nat -> ∀ (L: xlist), no_zeroes L -> xlist
with
no_zeroes := ...
On Mon, Feb 15, 2016 at 7:09 PM, Ilmārs Cīrulis <ilmars.cirulis AT gmail.com> wrote:
Here it is:Inductive list A: nat → Type :=| nil: list A 0| cons: ∀ n, A → list A n → list A (S n).Definition Language (A B: Type) := A → nat.Inductive Term A B (W: Language A B) :=| variable: nat → Term W| function_node: ∀ x, list (Term W) (W x) → Term W| binder_node: ∀ (b: B) (v: nat), Term W → Term W.Here I want to add the following condition in this inductive definition (for binder_node case).
Fixpoint variable_is_free A B (W: Language A B) (T: Term W) (x: nat) :=match T with| variable _ v => True| function_node _ L => Forall L (λ t, variable_is_free t x)| binder_node _ v t => v <> x ∧ variable_is_free t xend.It should be something similar to this:
Inductive Term A B (W: Language A B) :=| variable: nat → Term W| function_node: ∀ x, list (Term W) (W x) → Term W| binder_node: ∀ (b: B) (v: nat) (T: Term W), variable_is_free T v → Term Wwith variable_is_free A B (W: Language A B) := ...How can I do such thing?
- [Coq-Club] Question about mutual inductive definition with fixpoint, Ilmārs Cīrulis, 02/15/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Ilmārs Cīrulis, 02/15/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Benoît Viguier, 02/15/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Ilmārs Cīrulis, 02/16/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, roux cody, 02/17/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Frédéric Blanqui, 02/17/2016
