- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Question about mutual inductive definition with fixpoint
- Date: Mon, 15 Feb 2016 19:09:47 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=ilmars.cirulis AT gmail.com; spf=Pass smtp.mailfrom=ilmars.cirulis AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f175.google.com
- Ironport-phdr: 9a23:df37dxLhF0MU5OCuyNmcpTZWNBhigK39O0sv0rFitYgULPjxwZ3uMQTl6Ol3ixeRBMOAu60C17Od4v6ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILrjqvjpdX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVG679ZuEzSaFSJDUgKWE8osPx/1GXRgyWo3AYT28+kxxSAgGD4gusDbnrtS6vl+54czOBdeb3V60wWC/qu6ZvTRbyk2EMNiQk9GDMosN1haNf5hmmokoskMbvfIiJOa8mLevmdtQASD8ZUw==
Here it is:
Inductive list A: nat → Type :=
| nil: list A 0
| cons: ∀ n, A → list A n → list A (S n).
Definition Language (A B: Type) := A → nat.
Inductive Term A B (W: Language A B) :=
| variable: nat → Term W
| function_node: ∀ x, list (Term W) (W x) → Term W
| binder_node: ∀ (b: B) (v: nat), Term W → Term W.
Here I want to add the following condition in this inductive definition (for binder_node case).
Fixpoint variable_is_free A B (W: Language A B) (T: Term W) (x: nat) :=
match T with
| variable _ v => True
| function_node _ L => Forall L (λ t, variable_is_free t x)
| binder_node _ v t => v <> x ∧ variable_is_free t x
end.
It should be something similar to this:
| binder_node: ∀ (b: B) (v: nat) (T: Term W), variable_is_free T v → Term W
with variable_is_free A B (W: Language A B) := ...
How can I do such thing?
- [Coq-Club] Question about mutual inductive definition with fixpoint, Ilmārs Cīrulis, 02/15/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Ilmārs Cīrulis, 02/15/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Benoît Viguier, 02/15/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Ilmārs Cīrulis, 02/16/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, roux cody, 02/17/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Frédéric Blanqui, 02/17/2016
