- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question about mutual inductive definition with fixpoint
- Date: Tue, 16 Feb 2016 07:19:51 +0900
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=beviguier AT gmail.com; spf=Pass smtp.mailfrom=beviguier AT gmail.com; spf=None smtp.helo=postmaster AT mail-pa0-f45.google.com
- Ironport-phdr: 9a23:oCN/DBPauw9HyAIUE0Al6mtUPXoX/o7sNwtQ0KIMzox0KP/8rarrMEGX3/hxlliBBdydsKIbzbaM+Pi5EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35vxi7r5o8SbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5jfZSg7azHYaVeMKpSRJDBXE4QuyCp38rCr1q+twwgGVOMT3SfY/XjH0vPQjcwPhlCpSb21xy2rQkMEl1K8=
Would something like the following suit you ?
Inductive list :=
| nil
| cons : nat -> list -> list.
Fixpoint no_zeroes (L: list) := match L with
| nil => True
| cons n t => n <> 0 /\ no_zeroes t
end.
Inductive xlist : list -> Prop :=
| xlist_nil
xlist nil
| xlist_cons n l
(XLIST : xlist l)
(NOZEROS : n <> 0)
xlist (cons n l).
Fixpoint In n l := match l with
| nil => False
| cons h q => h = n \/ In n q
end.
Fact nonull : forall l, xlist l -> forall v, In v l -> v <> 0.
Proof.
intros.
induction H.
- auto.
- unfold In in H0.
destruct H0.
+ subst ; auto.
+ fold In in H0.
auto.
Qed.
2016-02-16 6:39 GMT+09:00 Ilmārs Cīrulis <ilmars.cirulis AT gmail.com>:
Inductive xlist :=Something likeHow to merge both into mutually inductive definitions? Is it possible?Fixpoint no_zeroes (L: list) := match L with nil => True | cons n t => n <> O /\ no_zeroes t end.Inductive list := nil | cons: nat -> list -> list.There is much smaller toy example. I have to apologise about not minimizing it previously.Let's take a list, that should contain only zeroes.
| nil
| cons: nat -> ∀ (L: xlist), no_zeroes L -> xlistwithno_zeroes := ...On Mon, Feb 15, 2016 at 7:09 PM, Ilmārs Cīrulis <ilmars.cirulis AT gmail.com> wrote:Here it is:Inductive list A: nat → Type :=| nil: list A 0| cons: ∀ n, A → list A n → list A (S n).Definition Language (A B: Type) := A → nat.Inductive Term A B (W: Language A B) :=| variable: nat → Term W| function_node: ∀ x, list (Term W) (W x) → Term W| binder_node: ∀ (b: B) (v: nat), Term W → Term W.Here I want to add the following condition in this inductive definition (for binder_node case).
Fixpoint variable_is_free A B (W: Language A B) (T: Term W) (x: nat) :=match T with| variable _ v => True| function_node _ L => Forall L (λ t, variable_is_free t x)| binder_node _ v t => v <> x ∧ variable_is_free t xend.It should be something similar to this:
Inductive Term A B (W: Language A B) :=| variable: nat → Term W| function_node: ∀ x, list (Term W) (W x) → Term W| binder_node: ∀ (b: B) (v: nat) (T: Term W), variable_is_free T v → Term Wwith variable_is_free A B (W: Language A B) := ...How can I do such thing?
- [Coq-Club] Question about mutual inductive definition with fixpoint, Ilmārs Cīrulis, 02/15/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Ilmārs Cīrulis, 02/15/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Benoît Viguier, 02/15/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Ilmārs Cīrulis, 02/16/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, roux cody, 02/17/2016
- Re: [Coq-Club] Question about mutual inductive definition with fixpoint, Frédéric Blanqui, 02/17/2016
