- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Doubt about In
- Date: Mon, 22 Feb 2016 12:51:00 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:VXUQmRW8WK6gK4ypF31Bkelmk5/V8LGtZVwlr6E/grcLSJyIuqrYZhCAt8tkgFKBZ4jH8fUM07OQ6PC/HzFcqs/Z6zgrS99laVwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oM2MJVgUz2PlOvtbF1afk0b4joEum4xsK6I8mFPig0BjXKBo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN/dwcbsNBzM/dmsx+cfDtB/ZTALJ6GFPfH8Rl09jB4nA4Rfmaa/wrm6/ne50xSWXOYWiRrQ5XDmk8+FzSQPAhyIONjp/+2bS3J8jxJlHqQ6s8kQsi7XfZ5uYYaJz
Indeed, this theorem does not seem to be true in general. Could it be that it
looks intuitively true because it holds in the classical framework?
Require Import List.
Require Import Classical.
Theorem strong_in_inv:
forall E (l: list E) e f,
In f (e :: l) -> e = f \/ (e <> f /\ In f l).
Proof.
intros.
simpl in H.
destruct H.
left; assumption.
classical_right; tauto.
Qed.
Note how ‘classical_right’ (instead of ‘right’ in your proof) gives you ‘not
(e = f)’.
Clément.
On 02/22/2016 12:32 PM, Arthur Azevedo de Amorim wrote:
> Hi Saulo,
> In order to prove this theorem, you need to assume that E has decidable
> equality:
> Require Import Coq.Lists.List.
> Import ListNotations.
> (forall x y : E, x = y \/ x <> y) ->
> Proof.
> intros R l e f eq_dec.
> simpl.
> destruct (eq_dec e f) as [H | H].
> - intros _. left. trivial.
> - intros [? | H']; try congruence.
> now right; split; trivial.
> Qed.
> Em seg, 22 de fev de 2016 às 12:27, Saulo Araujo
> <saulo2 AT gmail.com
> <mailto:saulo2 AT gmail.com>>
> escreveu:
> Hi,
> I am in the middle of a proof in which I need the following theorem:
> Unfortunately, I was not able to complete the proof below:
> Proof.
> intros.
> simpl in H.
> destruct H.
> left.
> apply H.
> right.
> split.
> (* I am stuck here! *)
> apply H.
> Qed.
signature.asc
Description: OpenPGP digital signature
- Re: [Coq-Club] Doubt about In, (continued)
- Re: [Coq-Club] Doubt about In, Saulo Araujo, 02/22/2016
- Re: [Coq-Club] Doubt about In, Arthur Azevedo de Amorim, 02/22/2016
- Re: [Coq-Club] Doubt about In, Emilio Jesús Gallego Arias, 02/22/2016
- Re: [Coq-Club] Doubt about In, Saulo Araujo, 02/23/2016
- Re: [Coq-Club] Doubt about In, Dominique Larchey-Wendling, 02/24/2016
- Re: [Coq-Club] Doubt about In, Saulo Araujo, 02/24/2016
