- To: Saulo Araujo <saulo2 AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Doubt about In
- Date: Mon, 22 Feb 2016 18:44:01 -0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=saulo2 AT gmail.com; spf=Pass smtp.mailfrom=saulo2 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f45.google.com
- Ironport-phdr: 9a23:DZd2UhWBFwWi9sN5QI2eZLw8LOHV8LGtZVwlr6E/grcLSJyIuqrYZhKAt8tkgFKBZ4jH8fUM07OQ6PC/HzFcqs/d4TgrS99laVwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oM2MJVgUz2PhMPtbF1afk0b4joEum4xsK6I8mFPig0BjXKBo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN/dwcbsNNz07N2d9zdfiqBvEBV+U72YYVT8+nR9BAgyD5xb/CNO5uSzj8+F5xSOyPMvsTLlyVy7xwb1sTUrTgToDMHYQ6mjKiMs42LlSvRam/TRwxofVZMeeM/8oLfCVRs8TWWcUBpUZbCdGGI7pN4Y=
Hi Emilio,
Have you got a small example of this technique that you could share?
Sincerely,
Saulo
On Mon, Feb 22, 2016 at 3:33 PM, Emilio Jesús Gallego Arias <e+coq-club AT x80.org> wrote:
Hi Saulo,
Saulo Araujo <saulo2 AT gmail.com> writes:
> Thanks a lot for your explanantion Artur. I have a feeling you are right
> and, sooner or later, I am gonna need the proof of the decidability of my
> dependent type. I am gonna keep it close to me :)
Note that if you can show an injection from your dependent type to a
type with decidable equality then you can transfer decidability (see
InjEqMixin in the math-comp library).
I find this trick quite useful when dealing with dependently-typed
syntax (as usually you can assume an upper bound), as usually my target
type is of the form { s : T | ... }.
Best,
E.
- [Coq-Club] Doubt about In, Saulo Araujo, 02/22/2016
- Re: [Coq-Club] Doubt about In, Arthur Azevedo de Amorim, 02/22/2016
- Re: [Coq-Club] Doubt about In, Saulo Araujo, 02/22/2016
- Re: [Coq-Club] Doubt about In, Emilio Jesús Gallego Arias, 02/22/2016
- Re: [Coq-Club] Doubt about In, Saulo Araujo, 02/23/2016
- Re: [Coq-Club] Doubt about In, Dominique Larchey-Wendling, 02/24/2016
- Re: [Coq-Club] Doubt about In, Saulo Araujo, 02/24/2016
- Re: [Coq-Club] Doubt about In (and refine), Jean-Francois Monin, 02/25/2016
- Re: [Coq-Club] Doubt about In (and refine), Saulo Araujo, 02/25/2016
- Re: [Coq-Club] Doubt about In, Emilio Jesús Gallego Arias, 02/24/2016
