- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Doubt about In
- Date: Wed, 24 Feb 2016 09:00:10 -0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=saulo2 AT gmail.com; spf=Pass smtp.mailfrom=saulo2 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f52.google.com
- Ironport-phdr: 9a23:uh71GBL47JFysektxdmcpTZWNBhigK39O0sv0rFitYgUKf7xwZ3uMQTl6Ol3ixeRBMOAu60C1rqd6P6ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILqh6vppdX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6072YYVS0/iBNVAQ+NuArzQ5P26AP1s+N83G+ROsigHuN8Yiir86o+EEygsywALTNsqGw=
Hi Dominique,
Thanks a lot for providing this shorter proof. I am going to study it with care so that I can apply similar techniques in other dependent type equalitity decidability proofs.
Sincerely,
Saulo
On Wed, Feb 24, 2016 at 7:49 AM, Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr> wrote:
Hi Saul,
May I suggest the following shorter proof for the decidability
of equality over List Digit n.
Section List.
Variable E : Type.
Inductive List : nat -> Type :=
| ListLeaf: E -> List 0
| ListNode n: E -> List n -> List (S n).
Definition List_leaf (l : List 0) := match l with | ListLeaf e => e end.
Definition List_head n (l : List (S n)) := match l with | ListNode _ e
_ => e end.
Definition List_tail n (l : List (S n)) := match l with | ListNode _ _
t => t end.
Hypothesis eqE_dec : forall x y : E, { x = y } + { x <> y }.
Definition List_inv_t n :=
match n return List n -> Type with
| 0 => fun a => { e | a = ListLeaf e }
| S n => fun a => { e : _ & { b | a = ListNode _ e b } }
end.
Definition List_inv n l : List_inv_t n l.
Proof.
destruct l as [ e | n e l ]; simpl.
exists e; reflexivity.
exists e, l; reflexivity.
Defined.
Definition eq_List_dec n (a b : List n) : { a = b } + { a <> b }.
Proof.
revert b; induction a as [ e | n e a IHa ]; intros b.
destruct (List_inv _ b) as (f & Hb).
destruct (eqE_dec e f) as [ | C ].
left; subst; reflexivity.
right; subst; contradict C.
apply f_equal with (f := List_leaf) in C.
apply C.
destruct (List_inv _ b) as (f & c & Hb).
destruct (IHa c) as [ | D ].
right; subst; contradict D.
apply f_equal with (f := List_tail _) in D.
apply D.
apply f_equal with (f := List_head _) in C.
apply C.
Defined.
End List.
Inductive Digit :=
| D0
| D1.
Definition eq_Digit_dec (x y : Digit) : { x = y } + { x <> y }.
Proof.
decide equality.
Defined.
Theorem List_Digit_dec:
forall n (cs ds: List Digit n), {cs = ds} + {cs <> ds}.
Proof.
apply eq_List_dec, eq_Digit_dec.
Defined.
Best regard,
Dominique
On 02/23/2016 12:49 PM, Saulo Araujo wrote:
> Hi Emilio,
> Thanks a lot for expanding your previous answer. As I´m studying
> dependent type programming in Coq in my spare time, it will take me some
> some days to try your suggestion. In any case, my dependent type is a
> very simple one:
> *Inductive List E: nat -> Type :=*
> *| ListLeaf: E -> List E 0*
> *| ListNode n: E -> List E n -> List E (S n).*
> *Inductive Digit :=*
> *| D0*
> *| D1.*
> Below is my proof of the decidability of List Digit n:
> *Theorem list_digit_dec:*
> * forall n (cs ds: List Digit n), {cs = ds} + {cs <> ds}.*
> *Proof.*
> * intros.*
> * induction n. *
> * assert ({c | cs = ListLeaf c}).*
> * refine match cs with*
> * | ListLeaf c => _*
> * end.*
> * exists c.*
> * reflexivity.*
> * destruct H as [c H].*
> * rewrite H.*
> * assert ({d | ds = ListLeaf d}).*
> * refine match ds with*
> * | ListLeaf d => _*
> * end.*
> * exists d.*
> * reflexivity.*
> * destruct H0 as [d H0].*
> * rewrite H0.*
> * destruct c.*
> * destruct d.*
> * apply left.*
> * reflexivity.*
> * apply right.*
> * unfold not.*
> * intros.*
> * inversion H1.*
> * destruct d.*
> * apply right.*
> * unfold not.*
> * intros.*
> * inversion H1.*
> * apply left.*
> * reflexivity.*
> * assert ({c: _ & {cs' | cs = ListNode c cs'}}).*
> * | ListNode _ c cs' => _*
> * end.*
> * exists c.*
> * exists cs'.*
> * reflexivity.*
> * destruct H as [cs' H].*
> * rewrite H.*
> * assert ({d: _ & {ds' | ds = ListNode d ds'}}).*
> * | ListNode _ d ds' => _*
> * end.*
> * exists d.*
> * exists ds'.*
> * reflexivity.*
> * destruct H0 as [ds' H0].*
> * rewrite H0.*
> * destruct c.*
> * destruct d.*
> * specialize IHn with cs' ds'.*
> * destruct IHn.*
> * left.*
> * congruence.*
> * right.*
> * contradict n0.*
> * inversion n0.*
> * apply inj_pair2_eq_dec.*
> * apply eq_nat_dec.*
> * apply H2.*
> * right.*
> * contradict H.*
> * inversion H.*
> * destruct d.*
> * right.*
> * contradict H.*
> * inversion H.*
> * destruct IHn.*
> * left.*
> * congruence.*
> * right.*
> * contradict n0.*
> * inversion n0.*
> * apply H2.*
> *Qed.*
> Sincerely,
> Saulo
> On Mon, Feb 22, 2016 at 7:51 PM, Emilio Jesús Gallego Arias
> <e+coq-club AT x80.org <mailto:e+coq-club AT x80.org>> wrote:
> Hi Saulo,
> Saulo Araujo <saulo2 AT gmail.com <mailto:saulo2 AT gmail.com>> writes:
> > Have you got a small example of this technique that you could share?
> I'm sorry I wasn't more concrete. I'll try to make an example without
> requiring external libraries.
> What I meant is a technique that actually happens two steps:
> a) Find an injective representation of your dependent type T into a
> "simpler" one U. This way, you can reuse the proof of decidability of
> U as this holds:
> 8<--------------------------------------------------------------------8<
> Section EqInj.
> Variable (T U : Type).
> Definition injective (f : T -> U) := forall (x y : T), f x = f y ->
> x = y.
> Definition eq_dec T := forall (x y : T), {x = y} + {x <> y}.
> Variable (f : T -> U).
> Hypothesis (f_inj : injective f).
> Hypothesis (U_dec : eq_dec U).
> Lemma eq_inj : eq_dec T.
> Proof.
> intros x y; destruct (U_dec (f x) (f y)) as [u_eq|u_neq].
> + now apply f_inj in u_eq; rewrite u_eq; left.
> + now right; intros xy_eq; apply u_neq; rewrite xy_eq.
> Qed.
> End EqInj.
> Fair enough, now the key is, what should U be? Usually you want U to be
> a type such that its decidability can be inferred automatically. This is
> what happens in math-comp if you use a combination of the basic data
> types, pairs, products, sigma types, etc...
> b) Composing decidability proofs:
> For instance, if two types are decidable, their sum is:
> Section EqSum.
> Hypothesis (T_dec : eq_dec T).
> Lemma sum_dec : eq_dec (T + U).
> Proof.
> intros [x1|y1] [x2|y2]; try (right; congruence).
> + destruct (T_dec x1 x2) as [t_eq|t_neq]; try (right; congruence).
> - now rewrite t_eq; left.
> + destruct (U_dec y1 y2) as [u_eq|u_neq]; try (right; congruence).
> - now rewrite u_eq; left.
> Qed.
> End EqSum.
> I learn this technique from the math-comp library where it is used
> extensively and may be the best source of examples. There you have the
> advantage that b) happens mostly automatically, so providing a) works
> quite well. A randomly picked example:
> > Definition natsum_of_int (m : int) : nat + nat :=
> > match m with Posz p => inl _ p | Negz n => inr _ n end.
> > Definition int_of_natsum (m : nat + nat) :=
> > match m with inl p => Posz p | inr n => Negz n end.
> > Lemma natsum_of_intK : cancel natsum_of_int int_of_natsum.
> > Proof. by case. Qed.
> > Definition int_eqMixin := CanEqMixin natsum_of_intK.
> > Definition int_countMixin := CanCountMixin natsum_of_intK.
> > Definition int_choiceMixin := CountChoiceMixin int_countMixin.
> Note that the same technique is used not only to derive decidability of
> equality but to derive countable and choice instances.
> The concrete example I was thinking of is following:
> imagine your original datatype T is a very complex dependent data type
> with lots of well-formedness conditions. This type may be hard to
> program and work with, however, there exists a forgetful injection into
> a type with no well-formedness conditions, but which has a composable
> decidability proof in virtue of its "simple" nature.
> Maybe it would help if you could post a small example of your dependent
> data type, so we could try to figure out whether there exists such an
> embedding or not.
> I hope it helps.
> E.
- [Coq-Club] Doubt about In, Saulo Araujo, 02/22/2016
- Re: [Coq-Club] Doubt about In, Arthur Azevedo de Amorim, 02/22/2016
- Re: [Coq-Club] Doubt about In, Saulo Araujo, 02/22/2016
- Re: [Coq-Club] Doubt about In, Emilio Jesús Gallego Arias, 02/22/2016
- Re: [Coq-Club] Doubt about In, Saulo Araujo, 02/23/2016
- Re: [Coq-Club] Doubt about In, Dominique Larchey-Wendling, 02/24/2016
- Re: [Coq-Club] Doubt about In, Saulo Araujo, 02/24/2016
- Re: [Coq-Club] Doubt about In (and refine), Jean-Francois Monin, 02/25/2016
- Re: [Coq-Club] Doubt about In (and refine), Saulo Araujo, 02/25/2016
- Re: [Coq-Club] Doubt about In, Emilio Jesús Gallego Arias, 02/24/2016
