coq-club - Re: [Coq-Club] overloading natural number notations for user types
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] overloading natural number notations for user types
  • Date: Mon, 22 Feb 2016 14:44:34 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f52.google.com
  • Ironport-phdr: 9a23:mAkilx9SUh6A+v9uRHKM819IXTAuvvDOBiVQ1KB91+scTK2v8tzYMVDF4r011RmSDdqdtq4P0rCL+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStGU0pj8jrrvs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGCmI4HIAUmwQ2j5FAhbI6g2yCpX2tCr5u+5w1QGVOMT3SfY/XjH0vPQjcwPhlCpSb21xy2rQkMEl1K8=
In this particular case, I did manage to use coercions. I did have to change a few tactics to accommodate the appearance of the coercion function, but it worked. It does feel a bit fragile, though. In particular, the user type that I want numerals to work for is also declared to be a ring, and I need ring-simplify to work properly even in other cases I haven't tried yet. Maybe I can rig the Add Ring declaration with the necessary preprocess/postprocess tactics to unfold/fold the coercion function?
But, I would like to avoid this by having everything handled in the parse/print layers.
As for Jason's question of how my "stupider" suggestion should handle open terms and printing, well, I did say it was stupider.
If there were concerns about the functions not providing an isomorphism (hence being able to appear to prove "2 = 3", for example) - then I guess it could require a Class with proofs that the two conversion functions provide an isomorphism.
-- Jonathan
On 02/22/2016 12:19 PM, Gregory Malecha wrote:
Would Coercions fit the bill for the nat2mynat idea? Or are they not
expressive enough.
On Sun, Feb 21, 2016 at 8:40 PM, Jason Gross
<jasongross9 AT gmail.com>
wrote:
Jonathan, how does that work on open terms? It'll work fine for parsing,
probably (though I don't really want to be able to do arbitrary computation
in the parsing of my numerals, that's perhaps a bit scary, but perhaps
useful), but seems kind-of sketchy for printing.
On Sun, Feb 21, 2016 at 9:08 PM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
I was thinking something even stupider than that! The user gives two
functions that map between nats and the user type they want to represent
with number notations:
Inductive mynat : Set := ...
Definition nat2mynat(n : nat) : mynat := ...
Definition mynat2nat(m: mynat) : nat := ...
Declare Nat Syntax mynat Using nat2mynat, mynat2nat : M_scope.
The parser would, whenever it sees a number in the scope M_scope, call
nat2mynat and use the result. The printer would, whenever it sees a mynat
in the scope M_scope, call mynat2nat, and print the resulting number.
-- Jonathan
On 02/21/2016 06:05 PM, Jason Gross wrote:
I was thinking something stupider: you pass in terms that are treated as
constructors and required to have the appropriate type signature (a type
"NAT", an "O : NAT", and an "S : NAT -> NAT" (hopefully the code can be
parametric over how many universes NAT uses, and whether its polymorphic
or
not, etc), and then notations get translated to applications of S and O,
and applications of S and O get translated back, and if S and O happen to
unfold to other things, then unfolding them breaks the notation (which is
not the end of the world).
Even better would be to generalize the nat_syntax_plugin to handle things
like [trunc_index], i.e., things where the base case should be displayed
as
1 or as -2, etc.
I do not think that we should have to trust Ltac code to get syntax for
custom natural numbers.
On Sun, Feb 21, 2016 at 5:49 PM, Pierre-Marie Pédrot <
pierre-marie.pedrot AT inria.fr>
wrote:
On 21/02/2016 23:31, Jason Gross wrote:
How hard would it be to set up the syntax plugins already in Coq so
that
they registered vernaculars such as [Declare NatSyntax for nat in
nat_scope [O S].] and similarly for notations for negative numbers,
ascii, strings, etc?
Not that difficult, I believe. Yet, we need to rely on a meta-language
to pattern-match over terms. Ltac would fit the bill, but I personally
find this use a little bit ugly. The vernacular would probably look
like:
Parameter myNat : Type.
Ltac reify_myNat n :=
match n with
(* insert a code producing a Z from a myNat here *)
end.
Declare Nat Syntax myNat reify_myNat.
PMP
