coq-club - Re: [Coq-Club] why are Coercions restricted to names?
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] why are Coercions restricted to names?
  • Date: Wed, 24 Feb 2016 20:05:20 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f49.google.com
  • Ironport-phdr: 9a23:wuvA8xJW/SAHmx1CkdmcpTZWNBhigK39O0sv0rFitYgULf3xwZ3uMQTl6Ol3ixeRBMOAu60C1rqd6vq8EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35vxirD5osePKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46Fp34d6XK77Z6U1S6BDRHRjajhtpZ6jiR6WZgyWrlAYT29exhFPGk3O6Azwdpb3qCrz8ORnjnq0J8rzGJI9QjOkp4hxTwTzwHMFPiU+9m7Njddr3YpUpRugo1p0xIuCM9LdD+Z3Yq6IJYBSfmFGRMsEEnUZWo4=
Much like the uniform inheritance condition, I believe the answer is "hysterical raisins" and "lack of time or manpower to fix it" and "pull requests are welcome".
You might be interested in [Set Keyed Unification] in Coq 8.5 (to handle your rewriting issue), bug #3115 (identity coercion limitations), bug #3389 (feature request for your "always unfolding", which I called "expand_invisible"), bug #2322 (terms as coercions), and bug #4593 (one I just reported about removing the uniform inheritance condition).
On Wed, Feb 24, 2016, 11:34 AM Jonathan Leivent <jonikelee AT gmail.com> wrote:
This is a follow-up to the "overloading natural number notations for
user types" thread.
Suppose one has a generic inductive type, such as:
Inductive foo(S : Set) : Set :=
| Foo(x : S).
And then wishes to declare coercions from various Sets, for example nat,
to the corresponding foo.  Coq does not allow the following:
Coercion (Foo nat) : nat >-> foo.
as it requires that the Coercion command's first arg is a name.  It also
doesn't allow using implicits, as in:
Arguments Foo {S} x.
Coercion Foo : nat >-> foo.
Instead, one must use an intermediate function for the coercion, such as:
Definition nat2foo := Foo nat.
Coercion nat2foo : nat >-> foo.
Why is there this restriction?  Why doesn't Coq allow partially
parameterized functions as coercions?
Note that this restriction would not be so bad if there was a way to
declare nat2foo as "always unfolding".  Meaning, not just something like
"Strategy expand [nat2foo].",  but that nat2foo is always immediately
unfolded - that it behaves almost like a notation. Otherwise, consider a
rewrite rule such as:
Variables F G : (foo nat) -> nat.
Axiom rw : F 1 = G 2.
Because rw was defined using the nat2foo coercion, it can't handle cases
where nat2foo doesn't appear:
Goal F 1 = G 2.
cbv. (*unfolds nat2foo*)
Fail rewrite rw.
-- Jonathan
