- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] why are Coercions restricted to names?
- Date: Thu, 25 Feb 2016 15:06:21 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f52.google.com
- Ironport-phdr: 9a23:PW7gyRAFxqf3MYvKdREyUyQJP3N1i/DPJgcQr6AfoPdwSP74rsbcNUDSrc9gkEXOFd2CrakU1KyI6uuxBCQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTokb7rsMyOKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs1kbVGwKkhNOSyzI7Q/3WIu55in9sOt+1S2XMOX5SLk1XXKp6KI9G0ygszsOKzNsqDKfscd3lq8O+B8=
Another similar problem with coercions - the source and destination types also have to be names, not terms. Hence, one cannot do:
Coercion f : (foo a) >-> (bar b).
I tried to fool this by using abbreviations, such as:
Notation fooa := (foo a).
Notation barb := (bar b).
Coercion f : fooa >-> barb.
Interestingly, the Coercion command in this case did not fail, but also did not have any impact.
I think I will add this to bug #2322.
-- Jonathan
On 02/24/2016 03:05 PM, Jason Gross wrote:
Much like the uniform inheritance condition, I believe the answer is
"hysterical raisins" and "lack of time or manpower to fix it" and "pull
requests are welcome".
You might be interested in [Set Keyed Unification] in Coq 8.5 (to handle
your rewriting issue), bug #3115
<https://coq.inria.fr/bugs/show_bug.cgi?id=3115> (identity coercion
limitations), bug #3389
<https://coq.inria.fr/bugs/show_bug.cgi?id=3389> (feature
request for your "always unfolding", which I called "expand_invisible"), bug
#2322 <https://coq.inria.fr/bugs/show_bug.cgi?id=2322> (terms as
coercions), and bug #4593 <https://coq.inria.fr/bugs/show_bug.cgi?id=4593>
(one
I just reported about removing the uniform inheritance condition).
On Wed, Feb 24, 2016, 11:34 AM Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
This is a follow-up to the "overloading natural number notations for
user types" thread.
Suppose one has a generic inductive type, such as:
Inductive foo(S : Set) : Set :=
| Foo(x : S).
And then wishes to declare coercions from various Sets, for example nat,
to the corresponding foo. Coq does not allow the following:
Coercion (Foo nat) : nat >-> foo.
as it requires that the Coercion command's first arg is a name. It also
doesn't allow using implicits, as in:
Arguments Foo {S} x.
Coercion Foo : nat >-> foo.
Instead, one must use an intermediate function for the coercion, such as:
Definition nat2foo := Foo nat.
Coercion nat2foo : nat >-> foo.
Why is there this restriction? Why doesn't Coq allow partially
parameterized functions as coercions?
Note that this restriction would not be so bad if there was a way to
declare nat2foo as "always unfolding". Meaning, not just something like
"Strategy expand [nat2foo].", but that nat2foo is always immediately
unfolded - that it behaves almost like a notation. Otherwise, consider a
rewrite rule such as:
Variables F G : (foo nat) -> nat.
Axiom rw : F 1 = G 2.
Because rw was defined using the nat2foo coercion, it can't handle cases
where nat2foo doesn't appear:
Goal F 1 = G 2.
cbv. (*unfolds nat2foo*)
Fail rewrite rw.
-- Jonathan
- Re: [Coq-Club] overloading natural number notations for user types, (continued)
- Re: [Coq-Club] overloading natural number notations for user types, Jason Gross, 02/21/2016
- Re: [Coq-Club] overloading natural number notations for user types, Pierre-Marie Pédrot, 02/21/2016
- Re: [Coq-Club] overloading natural number notations for user types, Jason Gross, 02/22/2016
- Re: [Coq-Club] overloading natural number notations for user types, Jonathan Leivent, 02/22/2016
- Re: [Coq-Club] overloading natural number notations for user types, Gregory Malecha, 02/22/2016
- Re: [Coq-Club] overloading natural number notations for user types, Jonathan Leivent, 02/24/2016
- [Coq-Club] why are Coercions restricted to names?, Jonathan Leivent, 02/24/2016
- Re: [Coq-Club] why are Coercions restricted to names?, Jason Gross, 02/24/2016
- Re: [Coq-Club] why are Coercions restricted to names?, Jonathan Leivent, 02/25/2016
