- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Optional elim restriction?
- Date: Thu, 10 Mar 2016 19:26:56 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT hera.mpi-klsb.mpg.de
- Ironport-phdr: 9a23:/Al2ZRwQctBvVJzXCy+O+j09IxM/srCxBDY+r6Qd0e4TIJqq85mqBkHD//Il1AaPBtWEraIUwLOP6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6NyZTnnLnro9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD88QIrJEbFP2mN+RlFf0LRAghZmsy/YjgsQTJZQqJ/HoVFGsMwTRSBA2Q1hj+UN/Try31/r5/xS+VFcjuTPUvRi/k6L1kHky7wBwbPiI0pTmEwvd7i7hW9U/5qg==
Hi,
> If you are using 8.5 you can do rewriting in Type. Instead of importing
> SETOID SETOIDCLASS, import SETOID CEQUIVALENCE CMORPHISMS. Then you can
> use crelation in place of relation. (Actually. If you don't mind having
> your signature notations living in Prop. You can use crelations with the
> usual imports. i just hate the mess that it makes out of my Proper
> declarations)
Oh, that is interesting -- thanks! I'll certainly try it, should this
come up again. (For now, it seems like we found another way.)
Will this work with the ssreflect rewrite?
Kind regards,
Ralf
> Sent from Yahoo Mail on Android
> <https://overview.mail.yahoo.com/mobile/?.src=Android>
> On Thu, 10 Mar, 2016 at 16:33, Ralf Jung
> <jung AT mpi-sws.org>
> wrote:
> Hi all,
> I'm working in an axiom-free Coq development, and the elim restriction
> is getting in our way. I considered moving parts of our development from
> Prop to Type, but Coq's support for that is pretty poor -- in terms of
> notation, but (most importantly) in terms of rewriting. The Setoid
> mechanism forces the relation to be "A -> A -> Prop".
> However (if I recall correctly), the elim restriction is actually only
> needed because Coq wants to remain compatible with classical axioms.
> Since we try hard to avoid these, it is rather unfortunate that we still
> have to pay this prize. Of course we could just assume an axiom
> "inhabited T -> T", but that would not reduce properly, and of course it
> would mean we are no longer axiom-free. (I'm not sure if the part about
> computation would practically matter, but foundationally, it'd be nice
> to keep everything computational.)
> So I wonder, would it be possible to add a flag to Coq to disable the
> elim restriction? Would that make sense? It's a little like
> type-in-type, except that it's not actually unsound if not combined with
> classical axioms.
> Kind regards,
> Ralf
- [Coq-Club] Optional elim restriction?, Ralf Jung, 03/10/2016
- Re: [Coq-Club] Optional elim restriction?, Roger Witte, 03/10/2016
- Re: [Coq-Club] Optional elim restriction?, Ralf Jung, 03/10/2016
- Re: [Coq-Club] Optional elim restriction?, Jacques-Henri Jourdan, 03/10/2016
- Re: [Coq-Club] Optional elim restriction?, Pierre-Marie Pédrot, 03/10/2016
