coq-club - Re: [Coq-Club] Rewrite everywhere
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Rewrite everywhere
  • Date: Tue, 22 Mar 2016 18:22:22 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=beviguier AT gmail.com; spf=Pass smtp.mailfrom=beviguier AT gmail.com; spf=None smtp.helo=postmaster AT mail-pf0-f169.google.com
  • Ironport-phdr: 9a23:tzaamhEgFSv/aXfyI/PY1J1GYnF86YWxBRYc798ds5kLTJ75pMuwAkXT6L1XgUPTWs2DsrQf27qQ6vyrCD1IyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/nh6brp9aCMk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y42X2MRFAZ/PQnK8RD3RN+luCbkt+Vg2SSAFcLzRLEwHz+l6vE4G1fTlC4bOmthoynsgctqgfcDrQ==
Hi Jacques-Pascal,
I don't know if this is what you are looking for but you have :
rewrite [<-] ?H [in ...]
which is equivalent to :
rewrite [<-] H [in ...].
this will replace every occurrences until it fails (care for infinite recursion !). If rewrite can not be applied to the goal it does nothing.
You also have
rewrite [<-] !H [in ...]
which is the same as "?" but will fail if it can not be applied at least once.
Kind regards.
2016-03-22 17:36 GMT+01:00 Jacques-Pascal Deplaix <jp.deplaix AT gmail.com>:
Hi,
I'm doing proofs in coq which requires a rewrite as soon as possible in
the proof and we've been struggling in finding a way to rewrite every
single occurrences of the current goal (which has « fun x =>
ThingsToRewrite … » and other nightmares).
We've come to the following solution:
Program Instance :
forall A B, subrelation (@pointwise_relation A B eq) eq.
Next Obligation.
apply func_ext_dep. intros. rewrite H. reflexivity.
Qed.
Program Instance :
forall A B C D E F G H I J K (f : A -> B -> C -> D -> E -> F -> G -> H
-> I -> J -> K), Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq
==> eq ==> eq ==> eq ==> eq) f.
Next Obligation.
compute. intros. f_equal; auto.
Qed.
Program Instance :
forall A B C D E F G H I J (f : A -> B -> C -> D -> E -> F -> G -> H
-> I -> J), Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq
==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
forall A B C D E F G H I (f : A -> B -> C -> D -> E -> F -> G -> H ->
I), Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
forall A B C D E F G H (f : A -> B -> C -> D -> E -> F -> G -> H),
Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
forall A B C D E F G (f : A -> B -> C -> D -> E -> F -> G), Proper (eq
Next Obligation.
Qed.
Program Instance :
forall A B C D E F (f : A -> B -> C -> D -> E -> F), Proper (eq ==> eq
Next Obligation.
Qed.
Program Instance :
forall A B C D E (f : A -> B -> C -> D -> E), Proper (eq ==> eq ==> eq
==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
forall A B C D (f : A -> B -> C -> D), Proper (eq ==> eq ==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
forall A B C (f : A -> B -> C), Proper (eq ==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
forall A B (f : A -> B), Proper (eq ==> eq) f.
Next Obligation.
Qed.
and then use setoid_rewrite instead of rewrite.
NOTE: the order of the Proper instances are relevant. The other way
around, it will loop infinity.
We were wondering if there was a nicer way to do that ? Maybe already in
the coq standard library ?
In other words, is there a standard way to rewrite everywhere in the
current goal ?
Cheers,
