coq-club - Re: [Coq-Club] Rewrite everywhere
  • From: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Rewrite everywhere
  • Date: Wed, 23 Mar 2016 15:55:48 +0100
Hi Matthieu,
Thank you for the answer.
Perhaps you could help us understand by explaining us what is the process followed by setoid_rewrite (i.e., what instances is searched for, and how two instances you give here are used).
Thanks,
JH
Le 23/03/2016 15:10, Matthieu Sozeau a écrit :
Hi,
I think setoid_rewrite should be able to infer all those instances, and adding a subrelation is the right way to make it use extensionality. However, the way subtyping is implemented only Proper eq f for any f is inferred, independently of the arity of f. Here one must show the subrelation relation for eq <= (pointwise_relation A eq ==> ?) that was infered from the rewrite. For the [Proper (pointwise_relation A eq ==> eq) exist'] instances to be automatically inferred, you hence need to add also the following two instances:
(* Proper eq exists' is infered automatically, and we need to show eq <= (pointwise_relation A eq ==> eq) *)
Instance : forall A (R : relation A) (refl : Reflexive R) , subrelation eq R.
Proof.
  reduce. subst. apply refl.
Qed.
(** This show that (pointwise_relation A eq ==> eq) is Reflexive *)
Instance reflexive_pointwise: forall A B C (R : relation C), Reflexive R -> Reflexive (pointwise_relation A (@eq B) ==> R)%signature.
Proof.
  reduce. red in H0.
  apply functional_extensionality_dep in H0. subst.
  reflexivity.
Qed.
Cheers,
-- Matthieu
Le mar. 22 mars 2016 à 18:55, Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr> a écrit :
To reformulate Jacques-Pascal question:
How to tell setoid_rewrite to use functional extensionality to rewrite under lambdas ?
We are able to define the following instance (which is basically functional extensionality) :
Program Instance :
  forall A B, subrelation (@pointwise_relation A B eq) eq.
So that rewriting happens when the context of the lambda is simple. We can then use setoid_rewrite to prove the following lemma:
forall A B (f g:A->B), (forall x, f x = g x) -> (fun x => f x) = (fun x => g x).
But if now we define :
Definition exists' {A:Type} P := exists (x:A), P x.
And we try to prove :
Lemma L :
  forall A (P1 P2:A -> Prop),
    (forall x, P1 x = P2 x) ->
    exists' (fun x => P1 x) = exists' (fun x => P2 x).
This does not work, because the lambda is applied to something. We need to define the instance :
Program Instance :
   forall A B (f : A -> B), Proper (eq ==> eq) f.
But this does not work if the lambda is not the last parameter of exist'. then we need all the others instances...
So the question becomes : is there any way to tell setoid_rewrite that any context is respectful of Liebniz equality ?
JH
Le 22/03/2016 18:22, Benoît Viguier a écrit :
Hi Jacques-Pascal,
I don't know if this is what you are looking for but you have :
rewrite [<-] ?H [in ...]
which is equivalent to :
rewrite [<-] H [in ...].
this will replace every occurrences until it fails (care for infinite recursion !). If rewrite can not be applied to the goal it does nothing.
You also have
rewrite [<-] !H [in ...]
which is the same as "?" but will fail if it can not be applied at least once.
Kind regards.
2016-03-22 17:36 GMT+01:00 Jacques-Pascal Deplaix <jp.deplaix AT gmail.com>:
Hi,
I'm doing proofs in coq which requires a rewrite as soon as possible in
the proof and we've been struggling in finding a way to rewrite every
single occurrences of the current goal (which has « fun x =>
ThingsToRewrite … » and other nightmares).
We've come to the following solution:
Program Instance :
Next Obligation.
apply func_ext_dep. intros. rewrite H. reflexivity.
Qed.
Program Instance :
forall A B C D E F G H I J K (f : A -> B -> C -> D -> E -> F -> G -> H
-> I -> J -> K), Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq
==> eq ==> eq ==> eq ==> eq) f.
Next Obligation.
compute. intros. f_equal; auto.
Qed.
Program Instance :
forall A B C D E F G H I J (f : A -> B -> C -> D -> E -> F -> G -> H
-> I -> J), Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq
==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
forall A B C D E F G H I (f : A -> B -> C -> D -> E -> F -> G -> H ->
I), Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
forall A B C D E F G H (f : A -> B -> C -> D -> E -> F -> G -> H),
Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
forall A B C D E F G (f : A -> B -> C -> D -> E -> F -> G), Proper (eq
Next Obligation.
Qed.
Program Instance :
forall A B C D E F (f : A -> B -> C -> D -> E -> F), Proper (eq ==> eq
Next Obligation.
Qed.
Program Instance :
forall A B C D E (f : A -> B -> C -> D -> E), Proper (eq ==> eq ==> eq
==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
forall A B C D (f : A -> B -> C -> D), Proper (eq ==> eq ==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
forall A B C (f : A -> B -> C), Proper (eq ==> eq ==> eq) f.
Next Obligation.
Qed.
Program Instance :
Next Obligation.
Qed.
and then use setoid_rewrite instead of rewrite.
NOTE: the order of the Proper instances are relevant. The other way
around, it will loop infinity.
We were wondering if there was a nicer way to do that ? Maybe already in
the coq standard library ?
In other words, is there a standard way to rewrite everywhere in the
current goal ?
Cheers,
Attachment: signature.asc
Description: OpenPGP digital signature
