- From: Jacques-Pascal Deplaix <jp.deplaix AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Rewrite everywhere
- Date: Wed, 23 Mar 2016 15:33:53 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jp.deplaix AT gmail.com; spf=Pass smtp.mailfrom=jp.deplaix AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f45.google.com
- Ironport-phdr: 9a23:0Fk9GxyUtopKwcTXCy+O+j09IxM/srCxBDY+r6Qd0e4QIJqq85mqBkHD//Il1AaPBtWLrasawLSN+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuSt6U1pr8ibv60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVHSODxe7kyZb1eFjUvdW4vt+PxshyWbwKE/2YRSSAumwFDCgyNwBziWp7womOutPI71CSCOcT3XZg7XD2j6+FgTxq+23RPDCIw7GyC0p84t6lcuh/0/xE=
Hi,
Thanks for your answer but it doesn't work. Well it sort of works for
some cases (it's horribly slow tho: 15s for one setoid_rewrite) and it
doesn't terminate otherwise.
Do you have an other solution/fix ?
Cheers,
On 03/23/2016 03:10 PM, Matthieu Sozeau wrote:
> Hi,
> I think setoid_rewrite should be able to infer all those instances, and
> adding a subrelation is the right way to make it use extensionality.
> However, the way subtyping is implemented only Proper eq f for any f is
> inferred, independently of the arity of f. Here one must show the
> subrelation relation for eq <= (pointwise_relation A eq ==> ?) that was
> infered from the rewrite. For the [Proper (pointwise_relation A eq ==>
> eq) exist'] instances to be automatically inferred, you hence need to
> add also the following two instances:
> (* Proper eq exists' is infered automatically, and we need to show eq <=
> (pointwise_relation A eq ==> eq) *)
> Instance : forall A (R : relation A) (refl : Reflexive R) , subrelation
> eq R.
> Proof.
> reduce. subst. apply refl.
> Qed.
> (** This show that (pointwise_relation A eq ==> eq) is Reflexive *)
> Instance reflexive_pointwise: forall A B C (R : relation C), Reflexive R
> -> Reflexive (pointwise_relation A (@eq B) ==> R)%signature.
> Proof.
> reduce. red in H0.
> apply functional_extensionality_dep in H0. subst.
> reflexivity.
> Qed.
> Cheers,
> -- Matthieu
> Le mar. 22 mars 2016 à 18:55, Jacques-Henri Jourdan
> <jacques-henri.jourdan AT inria.fr
> <mailto:jacques-henri.jourdan AT inria.fr>>
> a écrit :
> To reformulate Jacques-Pascal question:
> How to tell setoid_rewrite to use functional extensionality to
> rewrite under lambdas ?
> We are able to define the following instance (which is basically
> functional extensionality) :
> Program Instance :
> forall A B, subrelation (@pointwise_relation A B eq) eq.
> So that rewriting happens when the context of the lambda is simple.
> We can then use setoid_rewrite to prove the following lemma:
> forall A B (f g:A->B), (forall x, f x = g x) -> (fun x => f x) =
> (fun x => g x).
> But if now we define :
> Definition exists' {A:Type} P := exists (x:A), P x.
> And we try to prove :
> Lemma L :
> forall A (P1 P2:A -> Prop),
> (forall x, P1 x = P2 x) ->
> exists' (fun x => P1 x) = exists' (fun x => P2 x).
> This does not work, because the lambda is applied to something. We
> need to define the instance :
> Program Instance :
> forall A B (f : A -> B), Proper (eq ==> eq) f.
> But this does not work if the lambda is not the last parameter of
> exist'. then we need all the others instances...
> So the question becomes : is there any way to tell setoid_rewrite
> that any context is respectful of Liebniz equality ?
> JH
> Le 22/03/2016 18:22, Benoît Viguier a écrit :
>> Hi Jacques-Pascal,
>> I don't know if this is what you are looking for but you have :
>> rewrite [<-] *?*H [in ...]
>> which is equivalent to :
>> rewrite [<-] H [in ...].
>> this will replace every occurrences until it fails (care for
>> infinite recursion !). If rewrite can not be applied to the goal
>> it does nothing.
>> You also have
>> rewrite [<-] *!*H [in ...]
>> which is the same as "?" but will fail if it can not be applied at
>> least once.
>> Kind regards.
>> 2016-03-22 17:36 GMT+01:00 Jacques-Pascal Deplaix
>> <<mailto:jp.deplaix AT gmail.com>jp.deplaix AT gmail.com
>> <mailto:jp.deplaix AT gmail.com>>:
>> Hi,
>> I'm doing proofs in coq which requires a rewrite as soon as
>> possible in
>> the proof and we've been struggling in finding a way to
>> rewrite every
>> single occurrences of the current goal (which has « fun x =>
>> ThingsToRewrite … » and other nightmares).
>> We've come to the following solution:
>> Program Instance :
>> Next Obligation.
>> apply func_ext_dep. intros. rewrite H. reflexivity.
>> Qed.
>> Program Instance :
>> forall A B C D E F G H I J K (f : A -> B -> C -> D -> E -> F
>> -> G -> H
>> -> I -> J -> K), Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq
>> ==> eq
>> ==> eq ==> eq ==> eq ==> eq) f.
>> Next Obligation.
>> compute. intros. f_equal; auto.
>> Qed.
>> Program Instance :
>> forall A B C D E F G H I J (f : A -> B -> C -> D -> E -> F ->
>> G -> H
>> -> I -> J), Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq ==>
>> eq ==> eq
>> ==> eq ==> eq) f.
>> Next Obligation.
>> Qed.
>> Program Instance :
>> forall A B C D E F G H I (f : A -> B -> C -> D -> E -> F -> G
>> -> H ->
>> I), Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq ==>
>> eq ==> eq) f.
>> Next Obligation.
>> Qed.
>> Program Instance :
>> forall A B C D E F G H (f : A -> B -> C -> D -> E -> F -> G -> H),
>> Proper (eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq ==> eq) f.
>> Next Obligation.
>> Qed.
>> Program Instance :
>> forall A B C D E F G (f : A -> B -> C -> D -> E -> F -> G),
>> Proper (eq
>> Next Obligation.
>> Qed.
>> Program Instance :
>> forall A B C D E F (f : A -> B -> C -> D -> E -> F), Proper
>> (eq ==> eq
>> Next Obligation.
>> Qed.
>> Program Instance :
>> forall A B C D E (f : A -> B -> C -> D -> E), Proper (eq ==>
>> eq ==> eq
>> ==> eq ==> eq) f.
>> Next Obligation.
>> Qed.
>> Program Instance :
>> forall A B C D (f : A -> B -> C -> D), Proper (eq ==> eq ==>
>> eq ==> eq) f.
>> Next Obligation.
>> Qed.
>> Program Instance :
>> forall A B C (f : A -> B -> C), Proper (eq ==> eq ==> eq) f.
>> Next Obligation.
>> Qed.
>> Program Instance :
>> Next Obligation.
>> Qed.
>> and then use setoid_rewrite instead of rewrite.
>> NOTE: the order of the Proper instances are relevant. The
>> other way
>> around, it will loop infinity.
>> We were wondering if there was a nicer way to do that ? Maybe
>> already in
>> the coq standard library ?
>> In other words, is there a standard way to rewrite everywhere
>> in the
>> current goal ?
>> Cheers,
- [Coq-Club] Rewrite everywhere, Jacques-Pascal Deplaix, 03/22/2016
- Re: [Coq-Club] Rewrite everywhere, Benoît Viguier, 03/22/2016
- Re: [Coq-Club] Rewrite everywhere, Jacques-Henri Jourdan, 03/22/2016
- Re: [Coq-Club] Rewrite everywhere, Matthieu Sozeau, 03/23/2016
- Re: [Coq-Club] Rewrite everywhere, Jacques-Pascal Deplaix, 03/23/2016
- Re: [Coq-Club] Rewrite everywhere, Jacques-Henri Jourdan, 03/23/2016
- Re: [Coq-Club] Rewrite everywhere, Matthieu Sozeau, 03/24/2016
