coq-club - Re: [Coq-Club] proof uninformativeness vs. proof irrelevance
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] proof uninformativeness vs. proof irrelevance
  • Date: Sat, 23 Apr 2016 22:35:43 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f169.google.com
  • Ironport-phdr: 9a23:TW1AWxcHUvtZ0A9eY2aCLrsflGMj4u6mDksu8pMizoh2WeGdxc68ZB7h7PlgxGXEQZ/co6odzbGG4+a/AydauMbJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviq9uMOU4S3Wr1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/rJngsgCGRg+S7FMdVH8Xm1xGGV6Wwgv9W8LYuCv7repw22GzO8TwQfhgUD6i7rxrRRyugSEOMTJ/8WDLheR/iatapFSqoBkpkN2cW52cKPcrJvCVRtgdX2cUBss=
Do you need to have proof irrelevance and proof relevance for the same Prop? If so, I would like to understand your use case.
I guess it is safe to assume instances of proof relevance for some Props, and to simultaneously assume instances of proof irrelevance of some *other* Props.
Also, if the Props for which you want to assume proof irrelevance are decidable, you can use them in a proof irrelevant way:
Definition makeIrrelevant (P:Prop) `{Decidable P} := if (decide P) then True else False.
(I originally learnt about this trick from http://cstheory.stackexchange.com/questions/18962/formalizing-the-theory-of-finite-sets-in-type-theory/18967#18967)
On Sat, Apr 23, 2016 at 10:10 PM, Jonathan Leivent <jonikelee AT gmail.com> wrote:
Sigh... there's got to be a version that "works" - that captures Coq's uninformative Prop concept, yet is weaker than proof irrelevance.  Is it enough to restrict T to bool? :
Definition proof_uninformativeness := forall (P : Prop)(f : P -> bool)(p1 p2 : P), f p1 = f p2.
What I'm trying to do is to work in a context where proof irrelevance is inconsistent (because I need injectivity of some props), yet one can still have its benefits.  So, I would like to keep proofs relevant to other proofs, but not to non-Prop types somehow...
-- Jonathan
On 04/23/2016 09:55 PM, Abhishek Anand wrote:
It implies proof irrelevance, as shown below.
Definition distinguished(T : Type) := exists (a b : T), a <> b.
Definition proof_uninformativeness : Prop :=
   forall (P : Prop)(T : Type)(f : P -> T)(p1 p2 : P), distinguished T -> f
p1 = f p2.
Inductive InjectPT (P:Prop) : Type :=
| injectpt :  P -> InjectPT P
| dummy1 : InjectPT P
| dummy2 : InjectPT P.
Lemma distinguishedInjectPT : forall P, distinguished (InjectPT P).
Proof using.
   intros ?. unfold distinguished. exists (dummy1 P), (dummy2 P).
   discriminate.
Qed.
Definition uninject (P:Prop) (ip: InjectPT P) : option P :=
match ip with
| injectpt _ p => Some p
| _ => None
end.
Lemma invertSome (A:Type) (a b: A) :
   Some a = Some b -> a= b.
Proof using.
   intros H.
   inversion H.
   reflexivity.
Qed.
Lemma  proof_uninformativeness_implies_proof_irrelevance:
   -> forall (P : Prop) (p q : P), p = q.
Proof using.
   intros H ? ? ?.
   specialize (H P (InjectPT P) (injectpt P) p q (distinguishedInjectPT P)).
   apply (f_equal (uninject P)) in H.
   simpl in H.
   apply invertSome in H.
   assumption.
Qed.
-- Abhishek
http://www.cs.cornell.edu/~aa755/
On Sat, Apr 23, 2016 at 9:00 PM, Jonathan Leivent <jonikelee AT gmail.com>
wrote:
On 04/23/2016 08:41 PM, darktenaibre wrote:
Ah, that notprop predicate prevents this stupid observation though. You
can certainly write something like (fun T => forall P : Prop, ~ (@eq Type P
T)) which will easily block the previous proof, but it's probably unusable
this way. I do not have any idea for a clever solution to this problem
though.
On 04/24/2016 02:32 AM, darktenaibre wrote:
On 04/24/2016 02:21 AM, Jonathan Leivent wrote:
Definition proof_uninformativeness := forall (P : Prop)(S : Set)(f : P
-> S)(p1 p2 : P), f p1 = f p2.
Hi,
If you take f:=id, isn't it just proof irrelevance ?
Lemma proof_uninformativeness_irrelevance : proof_uninformativeness ->
   intros pu P; apply pu.
Qed.
Oops - my (embarrassing) mistake having Prop not be a subtype of Set. :-[
So, there would need to be some usable notprop predicate.
Hmm... maybe types having at least 2 distinguished instances are
sufficient? :
Definition proof_uninformativeness := forall (P : Prop)(T : Type)(f : P ->
T)(p1 p2 : P), distinguished T -> f p1 = f p2.
Is this a suitable replacement for all interesting use cases of proof
irrelevance?
-- Jonathan
