coq-club - Re: [Coq-Club] proof uninformativeness vs. proof irrelevance
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] proof uninformativeness vs. proof irrelevance
  • Date: Sun, 24 Apr 2016 00:22:36 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f170.google.com
  • Ironport-phdr: 9a23:P3f6EBIyIWSy3gWY99mcpTZWNBhigK39O0sv0rFitYgULPzxwZ3uMQTl6Ol3ixeRBMOAu6IC1LCd6fy6EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35TxiLr5ocGJKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBnxyOGcsocbvqBPrTA2V53JaXH9AwTRSBA2QxRv6X4zxvyiyn+x03iXSacT8TbEvWTmhqa5tQRnkziYGKzER/2Tei8g2h6Ve9kHy7ydjypLZNdnGfMF1ebnQKIsX
Your proof essentially shows that Erasable_inj implies proof relevance of Foo, and is thus inconsistent with assuming proof irrelevance of Foo :
(No was a Yes? Sorry if I am misunderstanding something.)
Inductive Erasable(A : Set) : Prop :=
  erasable: A -> Erasable A.
Arguments erasable [A] _.
Axiom Erasable_inj : forall {A : Set}{a b : A}, erasable a=erasable b -> a=b.
Inductive Foo : Prop :=
  foo: nat -> Foo.
Definition foo2erasable(f : Foo) : Erasable nat :=
  match f with
    | foo x => erasable x
  end.
Lemma FooRelevant : foo 1 <> foo 2.
Proof.
  intros H.  apply f_equal with (f := foo2erasable) in H.
  simpl in H.
  apply Erasable_inj in H.
  discriminate H.
Qed.
Do you need to assume Erasable_inj in its full generality? or just some specific instances for some sets?
If only certain instances suffice, and if there was a way to easily understand the implications of such instances, it may still be possible to safely have some instances of proof irrelevance.
More formally, if we assume  @Erasable_inj A for some set A, is there are a simple characterization of the Props (members of sort Prop) whose proof relevance become implied?
On Sat, Apr 23, 2016 at 11:35 PM, Jonathan Leivent <jonikelee AT gmail.com> wrote:
On 04/23/2016 10:35 PM, Abhishek Anand wrote:
Do you need to have proof irrelevance and proof relevance for the same
Prop? If so, I would like to understand your use case.
No.  The proof-relevance I have is limited to injectivity of a single Prop constructor with a single Set arg.  Other than that one, I'd like to have proof irrelevance elsewhere, however...
I guess it is safe to assume instances of proof relevance for some Props,
and to simultaneously assume instances of proof irrelevance of some *other*
Props.
I have a proof that injectivity of any Prop constructor over a non-Prop arg combined with irrelevance of any other Prop constructor that has a non-Prop arg is inconsistent.  See : https://github.com/jonleivent/mindless-coding/blob/master/erasable_relevance.v
Anyway, I fear that the trick you used in your proof - of a non-Prop constructor with a single Prop arg, combined with the a-proiri injectivity in Coq of all constructors over all args, means that there isn't a very useful weakening of proof irrelevance, since the constructor use cases for proof irrelevance are probably the most important.
Or, to say this differently, Coq could only support a useful weakened version of proof irrelevance if it didn't have a-priori injectivity over Prop fields in non-Prop constructors.
Thanks anyway,
-- Jonathan.
Also, if the Props for which you want to assume proof irrelevance are
decidable, you can use them in a proof irrelevant way:
Definition makeIrrelevant (P:Prop) `{Decidable
<http://www.cs.cornell.edu/~aa755/ROSCoq/coqdocnew/MathClasses.misc.decision.html#Decision>
P} := if (decide P) then True else False.
(I originally learnt about this trick from
http://cstheory.stackexchange.com/questions/18962/formalizing-the-theory-of-finite-sets-in-type-theory/18967#18967
-- Abhishek
