coq-club - [Coq-Club] is |x| a viable notation?
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] is |x| a viable notation?
  • Date: Wed, 4 May 2016 13:38:10 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f49.google.com
  • Ironport-phdr: 9a23:Wf0coxeW1Cf6r732nKopg0A4lGMj4u6mDksu8pMizoh2WeGdxc69YB7h7PlgxGXEQZ/co6odzbGG4ua4AydZuMrJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuLOU4R3Wb1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu3SNp41Rr1ADTkgL3t9pIiy7UGCHkOz4S43VXxeuR5VCUCR5xbjG5z1ryHSt+xn2SDcM9egHp4uXjH3zaBtQQPogSFPEzM47mzRloQkjqVdoRGsoxFy64HRaYCRcvF5e/WOLpshWWNdU5MJBGR6CYSmYt5KVrJZMA==
I would like to have:
Notation "| x |" := (length x) (at level 0) : nat_scope.
However, it seems that using vertical bars this way causes problems for the parser (Syntax error: [constr:operconstr level 200] expected after '|' (in [constr:operconstr])). Putting the notation at level 200 means I'd have to parenthesize it for virtually all uses. I thought by restricting this notation to nat_scope, I would get around the parser problems, but I can't get this to work.
Is this just not possible? If it is possible, what is the proper incantation?
This is in 8.5pl1.
-- Jonathan
