- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Cc: Hugo Herbelin <Hugo.Herbelin AT inria.fr>
- Subject: Re: [Coq-Club] is |x| a viable notation?
- Date: Fri, 6 May 2016 12:23:53 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sedrikov AT gmail.com; spf=Pass smtp.mailfrom=sedrikov AT gmail.com; spf=None smtp.helo=postmaster AT mail-ig0-f177.google.com
- Ironport-phdr: 9a23:lQ+gxB1/WwXs8aeBsmDT+DRfVm0co7zxezQtwd8ZsegRIvad9pjvdHbS+e9qxAeQG96LurQc1aGM7+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6DyZzpnLrus7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cYk7sb+sVBSaT3ebgjBfwdVWx+cjN92Mq+/xLEVE6E4mYWemQQiBtBRQbfplmuVZDo9yD+q+BV2S+APMSwQ6piChq46KI+YxLkkiYMfxck/2zNwphrga5BoRGmuTRwxofVZMeeM/8oLfCVRs8TWWcUBpUZbCdGGI7pKtJXV+c=
To avoid parsing issue, such as in "g | f | x | y |" whether as "g(|f|, x, |y|)" or as "g(|f(|x|, y)|)", I tend to prefer to use opening characters and closing characters.
┤x├ for instance, retains the overall "|" form, but adds the indication whether we are in an opening or a closing.
Plus there is less risks to intefere with already existing notations, such as "{ x | P }" (for sig, if I remember correctly).
2016-05-05 17:23 GMT+02:00 Jonathan Leivent <jonikelee AT gmail.com>:
On 05/05/2016 11:05 AM, Hugo Herbelin wrote:
Hi Jonathan,
As an extra note: Applications are parsed at level 10 and arguments of
applications at level 9. Such as the LL-style camlp4/5 underlying
parsing engine works, putting "| x |" at level < 10, i.e. at the level
of potential arguments of an application, would make that for
expressions of the form "| ident |" or "| ... + ident |", etc., the
parser would try to interpret "ident" applied to some argument
starting with "|" rather than seeing the "|" as matching the currently
opened "|".
Best,
Hugo
I guess that's what the following fragment from "Print Grammar constr" means:
| "10" LEFTA
[ SELF; LIST1 constr:appl_arg
I can deal with "| x |" at level 10, although this means having to parenthesize it for function arguments - but maybe I will compensate by turning most such functions into operators (at higher levels) themselves.
Thanks,
Jonathan
On Wed, May 04, 2016 at 05:17:24PM -0400, Jonathan Leivent wrote:
On 05/04/2016 04:56 PM, James Lottes wrote:
I've been usingInteresting. Apparently, it works for levels >= 10, but not for
Notation "| x |" := (abs x) (at level 50, format "| x |").
Though it's not without problems. It works well enough for me in most
parsing contexts (certainly not all), but tends to display with extra
parentheses: (|x|). For example, this works for me:
Lemma abs_triangle : |x+y| ≤ |x|+|y|.
I'll also be keen to hear if there's a better way.
Cheers,
James
levels < 10. OK - I will try 10.
Thanks,
-- Jonathan
On Wed, May 4, 2016 at 10:38 AM, Jonathan Leivent <jonikelee AT gmail.com> wrote:
I would like to have:
Notation "| x |" := (length x) (at level 0) : nat_scope.
However, it seems that using vertical bars this way causes problems for the
parser (Syntax error: [constr:operconstr level 200] expected after '|' (in
[constr:operconstr])). Putting the notation at level 200 means I'd have to
parenthesize it for virtually all uses. I thought by restricting this
notation to nat_scope, I would get around the parser problems, but I can't
get this to work.
Is this just not possible? If it is possible, what is the proper
incantation?
This is in 8.5pl1.
-- Jonathan
- [Coq-Club] is |x| a viable notation?, Jonathan Leivent, 05/04/2016
- Re: [Coq-Club] is |x| a viable notation?, James Lottes, 05/04/2016
- Re: [Coq-Club] is |x| a viable notation?, Jonathan Leivent, 05/04/2016
- Re: [Coq-Club] is |x| a viable notation?, Hugo Herbelin, 05/05/2016
- Re: [Coq-Club] is |x| a viable notation?, Jonathan Leivent, 05/05/2016
- Re: [Coq-Club] is |x| a viable notation?, Cedric Auger, 05/06/2016
