coq-club - Re: [Coq-Club] is |x| a viable notation?
  • To: Hugo Herbelin <Hugo.Herbelin AT inria.fr>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] is |x| a viable notation?
  • Date: Thu, 5 May 2016 11:23:27 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f48.google.com
  • Ironport-phdr: 9a23:AXinVBIlCx8rbd9IdNmcpTZWNBhigK39O0sv0rFitYgVK/7xwZ3uMQTl6Ol3ixeRBMOAu6MC07ad7PGocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC3oLvi6vtqtX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD89pozcNLUL37cqIkVvQYSW1+ayFmrPHs4DneQgzHxnYGWGgSkxwAVyjY4xa8fprruCb+t+xV2S+APMSwQ6piHXyJ6L4jYxv1gm9TPDkgtWrTl8ZYjaRBoRvnqQYpkKDOZ4TAFv14d7/ddNVSYWdAQMtXS2QVAIS6bogCC+cMFeldpoj54VAJqE3tVkGXGOrzx2oQ1TfN1qog3rFkSFme0Q==
On 05/05/2016 11:05 AM, Hugo Herbelin wrote:
Hi Jonathan,
As an extra note: Applications are parsed at level 10 and arguments of
applications at level 9. Such as the LL-style camlp4/5 underlying
parsing engine works, putting "| x |" at level < 10, i.e. at the level
of potential arguments of an application, would make that for
expressions of the form "| ident |" or "| ... + ident |", etc., the
parser would try to interpret "ident" applied to some argument
starting with "|" rather than seeing the "|" as matching the currently
opened "|".
Best,
Hugo
I guess that's what the following fragment from "Print Grammar constr" means:
| "10" LEFTA
[ SELF; LIST1 constr:appl_arg
I can deal with "| x |" at level 10, although this means having to parenthesize it for function arguments - but maybe I will compensate by turning most such functions into operators (at higher levels) themselves.
Thanks,
Jonathan
On Wed, May 04, 2016 at 05:17:24PM -0400, Jonathan Leivent wrote:
On 05/04/2016 04:56 PM, James Lottes wrote:
I've been using
Notation "| x |" := (abs x) (at level 50, format "| x |").
Though it's not without problems. It works well enough for me in most
parsing contexts (certainly not all), but tends to display with extra
parentheses: (|x|). For example, this works for me:
Lemma abs_triangle : |x+y| ≤ |x|+|y|.
I'll also be keen to hear if there's a better way.
Cheers,
James
Interesting. Apparently, it works for levels >= 10, but not for
levels < 10. OK - I will try 10.
Thanks,
-- Jonathan
On Wed, May 4, 2016 at 10:38 AM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
I would like to have:
Notation "| x |" := (length x) (at level 0) : nat_scope.
However, it seems that using vertical bars this way causes problems for the
parser (Syntax error: [constr:operconstr level 200] expected after '|' (in
[constr:operconstr])). Putting the notation at level 200 means I'd have to
parenthesize it for virtually all uses. I thought by restricting this
notation to nat_scope, I would get around the parser problems, but I can't
get this to work.
Is this just not possible? If it is possible, what is the proper
incantation?
This is in 8.5pl1.
-- Jonathan
